Samsung LCD TV: no picture/sound, red light blinks, white light on, ignores on/off
  • whatusername
    • Dec 2013
    • 456
    Re: Samsung LCD TV: no picture/sound, red light blinks, white light on, ignores on/of
    nevermind either way same result...
    so its looking like main board which i initially thought but dont wanna spend $100 on a used board that would have me at $140 into this tv that i can maybe sell for $200
    so if i can repair this main board that would be awesome
    • whatusername
      • Dec 2013
      • 456
      ok well I ordered a main board off ebay it came in today i installed and tv came to life so looks like blinking red light issue is more of a main board problem
      • dchang0
        • Jun 2014
        • 33
        I can confirm the exact same symptoms on the same model of TV and the same fix of buying a new board.
        One additional interesting note: if I left the TV on long enough, the main board would eventually boot up and the TV would work normally for as long as it was left on. Once it was turned off again (and it would turn off normally, even responding to the remote), it could be turned back on (with switch or remote) immediately. BUT, the longer it was shut off, the longer it would take to turn back on.
        I told ShopJimmy's tech about this additional symptom and they said their EEPROM replacement service would likely NOT fix the bad board, so I just bought a like-new main board off of ebay, which of course fixed the problem right away.
        A second note of interest: I can confirm that the damage to the main board was done by failing 1000uF capacitors in the power supply.
        WhatUserName: thanks for this thread--you helped me repair this TV with minimal wasted money.
        • johnboy1313
          • Nov 2012
          • 1959
          I just finished fixing this exact set with the exact same symptoms by changing C102 and C131 on the main board. For future readers, follow user budm's instructions here.
          https://www.badcaps.net/forum/showpo...7&postcount=36
          • Elecfronicsssss
            DA0NJJMBAG0 charging light blinks
            by Elecfronicsssss
            Laptop motherboard DA0NJJMBAG0
            PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
            CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
            GUIDE ME WITH THE PROBLEM..
            SUMMARY-
            1.NO 1.8VOLTS ON BIOS PIN NO 8.
            2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
            05-12-2025, 02:32 AM
          • ongobongo
            Dell Latitude 7420 - Status LED blinks white once
            by ongobongo
            Hi Guys
            I have a Dell Latitude 7420 here which doesn't want to boot.
            If i plug in a charger, the status LED blinks white once only, nothing more, no amber blinks.
            I'm trying to start it without battery as the old one inflated and had to come out.
            I've tried all kinds of startmethod, holding D, holding CRTL+ESC, holding M+power, nothing works. I've even checked voltage/current consumption: charger changes to 20V and 0,07A but despite the one white blink, nothing else happens.
            Does someone have an idea what i should look at / check?
            ongobongo
            03-23-2024, 10:49 AM
          • ruletero
            HP Omen only do not turn on, only flashes white light
            by ruletero
            Hi everyone
            Please help me with this laptop
            HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
            It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
            But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
            Bios was programmed with a working version, no changes.
            Voltages
            +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
            06-07-2023, 10:11 AM
            RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
            by sam_sam_sam
            I bought these LED light bars from Electronic Goldmine surplus store online
            These light bars are the nicest LED light bars I have ever seen in there online store
            I read the description of these light bars and said yeah right there bright at 9 volts
            Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
            But I thought I would give these a try only because they had both light bars on sale as a bundle...
            02-11-2021, 10:03 AM
          • stevenallauca
            HP laptop does not charge the battery, the light turns amber and then changes to white.
            by stevenallauca
            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
            - ACN (BQACN) 19.6v
            - ACP (BQACP) 19.6v
            - CMSRC (BQCMSRC) 19.6v
            - ACDRV...
            09-23-2024, 11:30 AM
