Akai LCT2060 LCD TV
  • Difficilus
    • Dec 2012
    • 19
    Akai LCT2060 LCD TV
    I could use a little help with this one. I'm trying to keep this little 20" TV out of the land fill. I have found a couple of rare main board replacements for about 50 bucks but don't want to pop it in with no fix or blow up a new replacement because something else is still amiss.
    Odd little Akai LCT2060 LCD TV (NT182_V02 Main Board) that won't come on and has no standby LED lit. Power in is supplied by a 12V 4A ac adapter and tests at 12.3 vdc. I did meter 4.8 vdc across the power switch. Nothing when pressing the switch.
    Visual inspection gives no apparent indication of bad electrolytic caps. None bulged or exploded. Electrolytic caps are G-Luxon (China o'course) 5X10mm, 1000uf, 16v, 85c. I would likely replace them on this board or a replacement board before putting it back together.
  • selldoor
    Slow Learner
    • 7870
    Re: Akai LCT2060 LCD TV
    Does the supply test at 12.3vdc under load?
    Does it have a led and does it stay lit when plugged into the TV
    • Difficilus
      • Dec 2012
      • 19
      In as much as it is connected to the TV ... yes it's under load. It will run a security dvr that requires the same adapter okay and I have swapped adapters out for each other. They both work okay in this case.
      There is no LED lit when connected to the adapter.
      Thanks.
      • selldoor
        Slow Learner
        • 7870
        I meant does the adapter have its own LED
        • Difficilus
          • Dec 2012
          • 19
          Oops. No led on the adapter.
          • selldoor
            Slow Learner
            • 7870
            OK some do some dont
            On the inverter board pic 3 just behind the connector there is a black? smd fuse
            with 80 on it
            On the main Board pic 2 bottom right corner there is a white and gold fuse
            and in the top right corner another the same - perhaps there are more?
              Lets check all the fuses and the LDO (Low Drop Out, 3-pin)voltage regulator ICs.
              Please read the link below my signatur on how to test the LDO and report the readings in the format as shown in the link.
              • Difficilus
                • Dec 2012
                • 19
                with 80 on it
                These three, F1 and F2 on the mainboard and the smd on the inverter board, are good. I also have a 10x loop I have used to examine the board. Have not noticed any other fuses.
                Thanks.
                • selldoor
                  Slow Learner
                  • 7870
                  Good - Plugged in and switched on? -On the left hand connector on the controller board Pic4 can you test the voltage on each pin - Meter on vDC20 black probe on a ground screw red probe on each pin.
                  Please post result with pin description off the board.
                  • Difficilus
                    • Dec 2012
                    • 19
                    Duty calls. I will have to finish the LDO checks later this evening or tomorrow.
                    I'll post when completed.
                    Thanks again.
                    • Difficilus
                      • Dec 2012
                      • 19
                      Sorry for the delay in getting back here.
                      Meter range is 20vdc :
                      12v, 4A, AC adapter output with no load is 12.3vdc.
                      Values given are after 5 minute warm up and with no connections to inverter or other boards :
                      12.21vdc at F1 and F2 (main board pic 2, top right and bottom right )
                      Reg 7 and Reg 4 are both AMC 1117 – 1.8, (top right main board pic) pin assignments and readings are the same for both :
                      A/G - p1 - 0v
                      O - p2 - 0v
                      I - p3 - .06v
                      Reg 1 - can't read information on this component:
                      A/G - p1 – 0.00 v
                      O - p2 - 4.97v
                      I - p3 - 12.21v
                      Reg 2 - can't read information on this component:
                      A/G - p1 - 0v
                      O - p2 - 0.58v
                      I - p3 - 0.06v
                      J3 main board to inverter board. No pin out legend or values on the main board.(Lower right main board pic 2)
                      p1 - 12.21v
                      p2 - 12.21v
                      p3 - 12.21v
                      p4 - 0.00 v
                      p5 - 0.00v
                      p6 - 0.00v
                      p7 - 0.06v
                      p8 - 0.06v
                      p9 - 4.96v
                      J2 main board to control board (J3). No pin out legend or values on the main board pin out labels here are off the control board and pin numbers are just started from one end of J2 with the flip of a coin:
                      ADCKEY1- p1 - 0.0 v
                      NO - p2 – 4.98v
                      VCC5V - p3 - 4.98v
                      LEDZX - p4 - 0.26v
                      LED1ZX - p5 - 4.60v
                      IRINTTx - p6 - 0.0 v
                      PWRSW - p7 - 0.0 v
                      LED2ZX - p8 - 0.24v
                      Reg 3 and Reg 5 (Pic 2 right side next to caps) are 8050SD switch mode regulators and pin assignments and readings are the same for both:
                      Vn - p1- 12.21v
                      Swout - p2- 0.06v
                      GND - p3- 0.00 v
                      Vos - p4- 0.06v
                      S.S. - p5- 0.01v
                      Reg 6, top left next to tuner, can't read information on component:
                      O - 0.0 v
                      G/stub - 0.0 v
                      I - 0.58v
                      • Difficilus
                        • Dec 2012
                        • 19
                        J2 main board to control board (J3) No pin out legend or values on the main board pin out labels here are off the control board and pin numbers are just started from one end of J2 with the flip of a coin:
                        ADCKEY1- p1 - 0.0 v
                        NO - p2 – 4.98v
                        VCC5V - p3 - 4.98v
                        LEDZX - p4 - 0.26v
                        LED1ZX - p5 - 4.60v
                        PWRSW - p7 - 0.0 v
                        LED2ZX - p8 - 0.24v
