Sanyo DP46849 46" LCD - Does not power up.
    Re: Sanyo DP46849 46" LCD - Does not power up.
    Originally posted by retiredcaps
    Some? Grab them ALL.
    Will if I can. Upstairs, 3rd floor, there's a whole room (classroom sized) dedicated to condemned equipment. Failed safety test or doesn't work... some of it's just obsolete and works fine! And you know what? I can't touch a single thing. Because they're worried if they give away or sell these items, they're liable for any injury as a result of attempted repair or failure of the device. Seriously... I told them I'd sign a million disclaimers but they wouldn't have it.
    • Deebeaux
      • 31
      I deal with this sort of thing all the time. It's sad. There's tons of equipment in all sorts of state, federal, school system owned organizations that just rots because some lawyer could take them to the cleaners if someone uses the equipment and gets injured through their own negligence or stupidity.
      Best Regards,
      Dave (aka Deebeaux)
      • Deebeaux
        • 31
        Replaced IC. What should I do next? Plug it in and check?
        Best Regards,
        Dave (aka Deebeaux)
          If you have a 25W or 40W (120V) lightbulb available, remove the fuse and touch it across it, or clip it to the terminals on the bulb. If there's a fault in the standby circuit, the bulb will stay lit, but if everything's fine, the bulb will flash then go out, and you should see a standby LED. When that is successful remove the bulb and attempt to power on TV normally (the TV will not start with a bulb in series but it will usually run in standby mode.)
          • Deebeaux
            • 31
            What if I don't have such light bulb available? I guess I can go buy a light bulb and a socket if there's no alternative. Fuse is soldered on so not sure how to attach bulb to board after it's removed, could solder bulb socket leads to board?
            Best Regards,
            Dave (aka Deebeaux)
              Then power it up without the bulb. You risk potential damage to the IC you replaced, but in most cases nothing will happen.
              • Deebeaux
                • 31
                If there's one thing I've learned, I don't fit in "most cases" statements. I'll pickup a socket and bulb this week and give it a go. Might as well add this tool to the arsenal since I seem to be tinkering with more TVs/Monitors these days. Just to clarify I'd wire the bulb in place of the fuse (removing the fuse) and looking for flash or steady on? And we are talking about the T6.3AH/250V fuse that does read line voltage (120VAC) when the TV is plugged in?
                Thanks!
                Best Regards,
                Dave (aka Deebeaux)
                  Yes, that fuse but you can also wire it in series with the live wire, or something like that. Get a 100W bulb and 25W bulb, which will cover most use cases.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    See
                    https://www.badcaps.net/forum/showpo...07&postcount=7
                    --- begin sig file ---
                    --- end sig file ---
                    • Deebeaux
                      • 31
                      Alright, built the rig, tested with a 40W bulb (that's what I had around the house) ... I was also able to get my hands on a 100W bulb for future needs. Enclosed picture of load-rig just for fun. Never mind the cracked bulb base, came that way out of the box, planning on exchanging next time I venture out of the house. Will open package and check this time. Argh.
                      The bulb flashed quickly and went out (40W) but no standby/pilot light. I did check for power between the 5VSTB and GND pin on the power board and I do get 5V now, just not sure where to go from here. I guess it's possible we've got a problem on the main board. This also came out of a near lightning strike house. Oh, and if it matters, I tried the procedure with everything plugged in to the power board and with nothing plugged in. May not have been the best method but I plugged everything in after reinstalling the board and transporting the TV to my home workshop.
                      I didn't want to just hit power without a pilot light because I've done that in the past on electronics before and let out the magic smoke in doing so.
                      Any advice is, as always, much appreciated.
                      Best Regards,
                      Dave (aka Deebeaux)
                        Neat!
                        What I would do is power up the TV without the bulb. Some TVs do a self-test of the power supply when powering up, if that fails then the standby light won't light or will blink an error code.
                        • Deebeaux
                          • 31
                          So plug it into the wall and hit the power button? I do not get standby light even without the bulb. Guess I should have mentioned that.
                          Should I plug everything back into the supply board or only certain things? Like maybe not the HV stuff?
                          Just being cautious because I had a similar situation (before I knew about the lightbulb trick) with a TV that I repaired the power board, did not have a pilot light, and when I hit the power button a lightning bolt shot out of some surface mount components rendering it not worth fixing. Had to replace entire board.
                          Dave
                          Neat!
                          Best Regards,
                          Dave (aka Deebeaux)
                            Connect everything as the TV should be connected. The lightbulb trick shows there is no short so you should be safe.
                            • Deebeaux
                              • 31
                              There's two connectors labeled High Voltage on the output of the board. They are seemingly identical. I assume they're for the CCFL back lights. Does it matter which connector goes in which socket? I took a picture of it before I disconnected it, but the markings are in such a way they're not visible unless they're unplugged. Totally may fault. If they do matter, I can take the rest of the back of the set off and see if I can figure out which one is which.
                              Best Regards,
                              Dave (aka Deebeaux)
                                It doesn't matter, though usually it's difficult to get them in the "wrong" way.
                                • Deebeaux
                                  • 31
                                  I didn't think it mattered, but I figured it was worth a shot to ask. I wasn't concerned about getting the connector into the socket incorrectly. There's two connectors and two sockets. Was curious if there's like Socket A and Connector A vs. Socket B and Connector B. Didn't want to melt down something if I A->B'd something.
                                  Best Regards,
                                  Dave (aka Deebeaux)
                                  • Deebeaux
                                    • 31
                                    Magnificent! Success! I had a blast doing this. I need to snap a pic of my Samsung to confirm it's a mainboard issue and it'll be done too (I've got another post going.)
                                    Then I'm off to tackle my Westinghouse that's been without HDMI for months. No longer afraid of tackling this sort of thing.
                                    Thanks again to everyone who helped. Off to watch a movie...
                                    EDIT: In case someone finds this post down the road, this TV does not have a pilot light. It's off when off and green when on.
                                    Best Regards,
                                    Dave (aka Deebeaux)
                                      Glad you got it fixed, and thanks for the repair feedback.
                                        Great! Looks nice
                                        • Ady2017
                                          SMD fuse soldering advice please
                                          by Ady2017
                                          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                                          11-07-2025, 12:03 PM
                                        • cj_reha
                                          Mystery 80s Sanyo cap - perhaps polymer?
                                          by cj_reha
                                          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                          01-06-2023, 09:24 AM
                                        • chazzo
                                          CH341 programmer advice, including jumpers seemingly reversed
                                          by chazzo
                                          I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                                          [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                                          I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                                          10-12-2025, 08:15 AM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
                                        • zlr8r
                                          Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                          by zlr8r
                                          Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                          i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                          09-16-2025, 09:54 AM
