Vizio P42HD (Plasma) 2 Vertical Lines
  • rayrod81
    • Oct 2010
    • 205
    Re: Vizio P42HD (Plasma) 2 Vertical Lines
    This is a common problem with this panel. The cause is a bad logic board. It is situated behind the main board. It is usually bad solder joints on the main processor and the resistor packs and buffer chips along the bottom of the board. The processor is BGA and will need to be reflowed. You can purchase a new logic board but they are fairly expensive ($80-$100) and the 6871qch038C is prone to this problem. The 6871qch060q is an updated version but it is almost impossible to find new. Replacing either of these with a used board will cause the "sparklies" which LG Panels are notorious for.
      Thanks for the info randtek. How likely do you think a reflow would be to fix this?
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • brad2157
        Vizio E70-E3 Two white vertical lines
        by brad2157
        I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
        Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
        Replacement main board - Boots up fine, but starting...
        12-13-2021, 05:11 PM
      • pni
        LG 49uf695v vertical coloured lines
        by pni
        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
        11-14-2025, 03:15 AM
      • viking509
        vizio e65 e3 LED tv color vertical lines center tv only
        by viking509
        I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
        03-21-2023, 12:48 AM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
