RCA L32WD22 no picture
    Re: RCA L32WD22 no picture
    OK, the LDO looks OK, but you are not getting enough BL_ON signal to turn on the backlights, I expect it to be >3VDC, the VDIM can be from 1~5V for dimming. So basically, the Main board is not putting out the correct signal for the inverter board to work.
      You can force the inverter on by cutting the BL_ON wire and then feed the BL_ON on the inverter board through 1K resistor with external 3V to see if the backlights will flash on. At this point you should look for replacement main board. By the way, you may want to read Basic LCD TV Troubleshooting guide on the the link under my signature.
      http://www.shopjimmy.com/catalogsear...?q=RCA+L32WD22
      • PTaylor
        • Sep 2014
        OK, running into almost the same thing.Found that the power supply was bad (bad caps), replaced those. Can get the screen to flash on for a second but then goes out. Voltages are good (except my 12V line, it runs high also, like 13.4V).
        Pulled the inverter board, checking around with DMM set to Resistance and found one of the output driver coils measures higher than the others (15K as apposed to 3.XK).
        Would this make the display flash on and then go off?
        Looking for another inverter board (cheap) but haven't found one yet that matches what I have. Would LOVE just to find the Xfmrs.....
        I've got nothing in this right now except time, TV was given to me, would like to get it going but really, not winning or losing anything either way.....
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • CyberPhoenix
          Issue with picture quality of Sony bravia TV
          by CyberPhoenix
          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
          01-22-2024, 02:08 AM
