Wharfedale LCD47F1080p marks on inside screen
  • flocko
    • Nov 2012
    • 1121
    • uk
    Hi All just picked this up and it appears to have some kind of stain on the back of the screen that the backlights pickup as if something has been spilt on it,apart from this it all good.So my problem is how much of a job is it going to be to get to clean this up and any tip on how not to muck it up? I tried to take photos but the marks wont show up. thanks
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Wharfedale LCD47F1080p marks on inside screen
    It should be easy to take apart, TV's usually are compared to monitors. Try messing with some camera settings to try and pick it up in a picture, try with flash off, macro mode, etc
    • flocko
      • Nov 2012
      • 1121
      • uk
      I did try all the setting on my camera but they all failed to pick it up, its not bad just annoying starts at the top of the screen to about midway down in three places, the set is covered in dust and this happened after the guy moved and the set was left in storage. I think with all the dust that maybe it was raining when he moved, I will take photos when i pull it apart more for me so it all goes back the way it should, Any help on striping the panel would be gratefully received
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        You will need a room as dust free as possible -even then you will get some dust in. Read up on it before you do it - if you are keeping the set and can put up with it it may be better than dust.
        You may be able to find videos on youtube
        • flocko
          • Nov 2012
          • 1121
          • uk
          Thanks selldoor for pointing me over to youtube it seems this is a common fault and it is the polarizing film that wrinkles in the back of the screen. someone on there said to try an ice pack over the screen to shrink it back, oh well ill try anything once if not i will pull it apart.
            I have found loosening the screws to reduce the effect and also dropping the backlight a little.
            • flocko
              • Nov 2012
              • 1121
              • uk
              Hi Tom the screws you refer to are you talking about the metal panel frame ? And backlight setting would be in the factory setup menu i guess would you know the access code for this set. thanks
              • gilly1984
                • Jun 2012
                • 751
                Some tvs backlights cant be lowered.
                If its been in storage for a while it might have been a little damp, and the damp could of carried some of the dust in between the film layers.
                Not sure how possible that is though.
                Take apart and clean it, make sure its perfect before putting back together, even a little strand of hair will be visible at certain angles.
                Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                  Access code for Vestel
                  Menu then 4 7 2 5
                  Backlight is under picture settings config. 255 is dimmest, 0 is brightest on most Vestels.
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    Thanks Tom factory setup should also tell me what panel it has, i will try all these things later as i seem to have a bad case of man flu.I will let you know if i and the set survive.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • ipatch
                      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                      by ipatch
                      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                      08-24-2024, 02:36 PM
