RCA 32 lcd tv
  • nelfig
    • 23
    • canada
    RCA 32 lcd tv
    Ok so im new at fixing lcd tv's i just received a rca 32 inch lcd tv what it does it turns on i can see the back light on and then 5 seconds later it shuts off back into stand by mode ive opened it up but see no caps bulging or blown so what could it be inverter board or power board or tuner board the model is rlc3273a-b
    Re: Need help with rca 32 lcd tv
    I'd suggest a mod move this to the TV forum.
    A good start is to let us know what equipment you have: soldering iron, digital multimeter, etc.
    Second step is to post pictures, clear and in focus, of the TV's boards and one of the overall layout. Pictures up to 2000x2000 are supported; keep them around that size so we can clearly see the layout and the components.
    • nelfig
      • 23
      • canada
      sorry for posting in wrong forum and yes i do have a multimeter and soldering gun magnafineglass and such here are some pics i hope it helps
      model for power board cv318h-x
      model for tuner board mp116a rev 1.0
      model for inverter board v327-101 made by darfon
        OK, do you see a pin marked 24V on the power supply?
        Check the voltage here, using DC200V, black probe on chassis, red probe in pin area.
        • nelfig
          • 23
          • canada
          only one i seen on the power board was this one i did what you said and the reading i got was 35.4 but that cable goes from the power board to the inverter board
            Your meter needs to be set to DC volts, not AC volts.
            If reading is still high replace meter battery.
            • nelfig
              • 23
              • canada
              thats what it was set at and realized my batterywas no good now its reading 23.5
              • nelfig
                • 23
                • canada
                so my guess is the inverter board is not working then
                  That would be a possible suspect. Is there a pin marked ON/OFF, BLON or BLON/OFF on the power supply?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: RCA 32 lcd tv
                    Moved as requested.
                    sigpic
                    (Insert witty quote here)
                    • nelfig
                      • 23
                      • canada
                      Re: RCA 32 lcd tv
                      no just where the cable connects there is just ps on
                        Re: RCA 32 lcd tv
                        OK, that is unrelated for now. PSU is switched on (PSON) because 24V is present. Can we have a close picture of the inverter board?
                          Re: RCA 32 lcd tv
                          Please post a good closed up pictures of the area around the white connector (the one that the 24v from power supply is connected to) on the inverter board. Darfon!
                            Re: RCA 32 lcd tv
                            Darfon?
                            Run! Although, often easy fix...
                            • nelfig
                              • 23
                              • canada
                              Re: RCA 32 lcd tv
                              power supply connectors
                              right side
                              middle
                              left side
                                Re: RCA 32 lcd tv
                                OK, thanks for the pictures, but please edit the post and use GO ADVANCED, MANAGE ATTACHMENT to up load the pictures instead of posting them in line which takes a long time to display the pictures.
                                If you look to the right of that multi-pin connector on the inverter board, there are printings that show the pin outs of the connector, check the DC voltage between the BL_ON pin and the chassis ground to see if you still have >3VDC when the screen black out.
                                See if this PANASONIC has the same dimensions:
                                http://www.digikey.com/product-detai...0759-ND/285441
                                Digikey does not have it in stock but you can check other place like MOUSER.
                                • nelfig
                                  • 23
                                  • canada
                                  Re: RCA 32 lcd tv
                                  it comes up as 5v
                                    Re: RCA 32 lcd tv
                                    OK, so when the backlights go out, the required voltage (24VDC) is present, the turn on command (BL_ON) is also present, but the lamps still go into shutdown. Then you need to look at the inverter board.
                                    1) Check all the fuses (Fx) using 200 Ohm scale, they should show less than 1 Ohm.
                                    2) I would check the transformer secondary high voltage winding of all the transformers to see if they are all within 3% of each other.
                                    P/ as printed on the inverter transformer?
                                    Notes: also check pin 14 (??? PWM) to see what you have.
                                    • gopher
                                      • 3
                                      Re: RCA 32 lcd tv
                                      Hey there nelfig,
                                      I just got the same tv with the same problem, were you able to find the problem?
                                      • gopher
                                        • 3
                                        Re: RCA 32 lcd tv
                                        What should i have on pin 14?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
