Ok so im new at fixing lcd tv's i just received a rca 32 inch lcd tv what it does it turns on i can see the back light on and then 5 seconds later it shuts off back into stand by mode ive opened it up but see no caps bulging or blown so what could it be inverter board or power board or tuner board the model is rlc3273a-b
RCA 32 lcd tv
Re: Need help with rca 32 lcd tv
I'd suggest a mod move this to the TV forum.
A good start is to let us know what equipment you have: soldering iron, digital multimeter, etc.
Second step is to post pictures, clear and in focus, of the TV's boards and one of the overall layout. Pictures up to 2000x2000 are supported; keep them around that size so we can clearly see the layout and the components.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
sorry for posting in wrong forum and yes i do have a multimeter and soldering gun magnafineglass and such here are some pics i hope it helps
model for power board cv318h-x
model for tuner board mp116a rev 1.0
model for inverter board v327-101 made by darfonLast edited by nelfig; 01-09-2013, 12:31 PM.Comment
OK, do you see a pin marked 24V on the power supply?
Check the voltage here, using DC200V, black probe on chassis, red probe in pin area.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Your meter needs to be set to DC volts, not AC volts.
If reading is still high replace meter battery.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That would be a possible suspect. Is there a pin marked ON/OFF, BLON or BLON/OFF on the power supply?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: RCA 32 lcd tv
OK, that is unrelated for now. PSU is switched on (PSON) because 24V is present. Can we have a close picture of the inverter board?Last edited by tom66; 01-10-2013, 01:48 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: RCA 32 lcd tv
Please post a good closed up pictures of the area around the white connector (the one that the 24v from power supply is connected to) on the inverter board. Darfon!Never stop learning
Re: RCA 32 lcd tv
OK, thanks for the pictures, but please edit the post and use GO ADVANCED, MANAGE ATTACHMENT to up load the pictures instead of posting them in line which takes a long time to display the pictures.
If you look to the right of that multi-pin connector on the inverter board, there are printings that show the pin outs of the connector, check the DC voltage between the BL_ON pin and the chassis ground to see if you still have >3VDC when the screen black out.
See if this PANASONIC has the same dimensions:
http://www.digikey.com/product-detai...0759-ND/285441
Digikey does not have it in stock but you can check other place like MOUSER.Last edited by budm; 01-10-2013, 03:05 PM.Never stop learning
Re: RCA 32 lcd tv
OK, so when the backlights go out, the required voltage (24VDC) is present, the turn on command (BL_ON) is also present, but the lamps still go into shutdown. Then you need to look at the inverter board.
1) Check all the fuses (Fx) using 200 Ohm scale, they should show less than 1 Ohm.
2) I would check the transformer secondary high voltage winding of all the transformers to see if they are all within 3% of each other.
P/ as printed on the inverter transformer?
Notes: also check pin 14 (??? PWM) to see what you have.Never stop learning
Re: RCA 32 lcd tv
What should i have on pin 14?OK, so when the backlights go out, the required voltage (24VDC) is present, the turn on command (BL_ON) is also present, but the lamps still go into shutdown. Then you need to look at the inverter board.
Notes: also check pin 14 (??? PWM) to see what you have.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
