lg 60 pc1d recycles clicking
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    #41
    Re: lg 60 pc1d recycles clicking
    i did at the wire harness
      You need to do it at the connector on the PSU, as you've unplugged the wire harness from the PSU, right?
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        #43
        yea that is where i tried to take the reading from.
          So you get 0V (nearly) on Vs, Va whenever the connector is -not- plugged in?
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            #45
            yea only time i get a reading is when the x any y is connected
            • tocold4u2
              • Dec 2012
              • 284
              • usa
              #46
              idk could the meter be bad or what ?
                Test your meter on a 1.5V battery to get an indication if it is functioning.
                Can you supply a top-down picture of the PSU?
                • tocold4u2
                  • Dec 2012
                  • 284
                  • usa
                  #48
                  i tested the meter in a outlet it works. i took another reading on the tv still the same . and after the cycling of clicks stops the vs reads 90 the the va is 0
                  • tocold4u2
                    • Dec 2012
                    • 284
                    • usa
                    #49
                    here is 2 pictures
                    • tocold4u2
                      • Dec 2012
                      • 284
                      • usa
                      #50
                      could i have a shorted board ? or a pannel?
                        You need to try the DC volts scale of your meter on a battery. Outlet is good and all but only tells us if AC scale works.
                        We will need a clearer photo than that.
                        If the Va (panel) was shorted you would likely see 0V though you could rule it out by unplugging the Va wire on the Y- and Z-Sustain boards. Be careful, do not plug this in while the set is running.
                        Va is only used by the plasma panel drivers which are bonded to the panel. So either panel is shot, which is very rare to be honest, or the PSU has a problem... bets on the PSU.
                        • tocold4u2
                          • Dec 2012
                          • 284
                          • usa
                          #52
                          here is a few more pictures
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            #53
                            and here is two more
                              Again, I can see very little in those photos.
                              Remember the photos are my eyes. I do not have this board in front of me so I do not know what it looks like and how it is laid out.
                              • tocold4u2
                                • Dec 2012
                                • 284
                                • usa
                                #55
                                i have some pictures that i took with the camera instead of the phone,,,,i just got to figure out how to make them smaller first. and i tested a battery,,,,,,1.48 so yea its working
                                • tocold4u2
                                  • Dec 2012
                                  • 284
                                  • usa
                                  #56
                                  i hope this works
                                    I still need clear pic of PSU, as close as possible to 2000x2000 pixels.
                                    • tocold4u2
                                      • Dec 2012
                                      • 284
                                      • usa
                                      #58
                                      these are 2000x1600 i can only load one at a time
                                        I need a pic of the PSU only. Remember your pictures are my eyes I do not have this chassis in front of me and have never worked on it myself.
                                        • tocold4u2
                                          • Dec 2012
                                          • 284
                                          • usa
                                          #60
                                          first pic
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
