Viewsonic N3735W
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • ravi_1617
    VBU30 LA-9223P ,stay on for 5 seconds,
    by ravi_1617
    Hi to all.
    This HP board LA-9223P stays on for not more than 5 seconds,
    Problem no V-core power .
    PL302 3.3+3VALWP OK
    PL303 5+5VALWP OK
    PL402 1.5 VP OK
    PL602 1.8 VSP OK
    PL5021.08 VCCP OK
    PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
    PL204 .7 Mil VOLT+VGFX_CORE
    PL202 2.2 mIL Volt +CPU_CORE
    Please Help
    https://www.badcaps.net/forum/troubl...eed-schematic-...
    02-05-2025, 09:36 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • rstrube
    ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
    by rstrube
    Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
    Hi Everyone,
    I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
    11-23-2025, 01:37 PM
  • rstrube
    by rstrube
    Hi Everyone,
    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
    11-23-2025, 12:19 PM
