Viewsonic N3735W
    Re: Viewsonic N3735W
    I am not sure the way the resistance is posted with the - in front for each display line or it is actually negative symbol.
    • kmoonen
      • Dec 2011
      • 61
      the - is just a dash, not a negative symbol
        In which case remove #7 to confirm as budm suggests, and I would consider replacing it. Likely the fault.
        • drifter
          • Jun 2011
          Hi... i hate to start a new thread when ive got the same problem.. so here i am
          anywho... ive got the same tv with the same problem.. same readings for the most part... but my part number is different 6019b723009 (gp)
          Wich i cant seem to find. budm posted a link to lcdparts place with a transformer with real close to the same readings as the other ones on the board.
          my question is.. would this transformer work or no?
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • ravi_1617
            VBU30 LA-9223P ,stay on for 5 seconds,
            by ravi_1617
            Hi to all.
            This HP board LA-9223P stays on for not more than 5 seconds,
            Problem no V-core power .
            PL302 3.3+3VALWP OK
            PL303 5+5VALWP OK
            PL402 1.5 VP OK
            PL602 1.8 VSP OK
            PL5021.08 VCCP OK
            PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
            PL204 .7 Mil VOLT+VGFX_CORE
            PL202 2.2 mIL Volt +CPU_CORE
            Please Help
            https://www.badcaps.net/forum/troubl...eed-schematic-...
            02-05-2025, 09:36 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • rstrube
            ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
            by rstrube
            Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
            Hi Everyone,
            I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
            11-23-2025, 01:37 PM
          • rstrube
            by rstrube
            Hi Everyone,
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
            11-23-2025, 12:19 PM
