Viewsonic N3735W
+ More Options
Posts
  • ravi_1617
    VBU30 LA-9223P ,stay on for 5 seconds,
    by ravi_1617
    Hi to all.
    This HP board LA-9223P stays on for not more than 5 seconds,
    Problem no V-core power .
    PL302 3.3+3VALWP OK
    PL303 5+5VALWP OK
    PL402 1.5 VP OK
    PL602 1.8 VSP OK
    PL5021.08 VCCP OK
    PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
    PL204 .7 Mil VOLT+VGFX_CORE
    PL202 2.2 mIL Volt +CPU_CORE
    Please Help
    https://www.badcaps.net/forum/troubl...eed-schematic-...
    02-05-2025, 09:36 AM
  • fab13
    PS4 lights up for a few seconds (blue led) and shuts down - non-rotating fan
    by fab13
    I have a ps4 Fat CUH-1116A, the worry is that when I got it back it turns on with the blue leds and a few seconds it turns off and you have to turn it back on and it turns off again.
    It seems to be in security.
    The fan does not turn even with a new one
    Motherboard SAB-001
    Checking made:
    - New power supply block OK and even with another one always the same problem
    - PS4 metal sheet is not too screwed
    - New thermal paste and new fan
    - Voltage 12 Volts arrived on the fan, no short circuit on the 12 V ...
    11-26-2022, 09:00 AM
  • liquidzorch
    Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
    by liquidzorch
    Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
    10-18-2024, 05:19 PM
  • EazyBone
    Qn65q800taa won't start
    by EazyBone
    Did some of the usual troubleshooting.
    Unplug main board connector and back lights come on and stay on and PSU supplies all correct voltages on the legend.
    When you just plug in the TV the PSU relay clicks on and off immediately and then continues to click on and off every 20 seconds or so. The red light on the front flashes once and then 5 to 8 seconds later flashes once again and continues the cycle with the relay.
    I've disconnected each you ribbon cable one at a time and every single T-Con cable one at a time to see if there's any change. No change as long...
    03-20-2025, 12:47 PM
