NIKOS MOSFET replacements
+ More Options
Posts
  • richr69
    • Jul 2010
    • 58
    Does anybody know a suitable substitute for the following MOSFETs made by NIKO-SEM:
    NIKOS P1504BDG (N-Chan)
    Vdss = 40V
    Rds = 15mOhm
    Id = 40A
    NIKOS P2504EDG (P-Chan)
    Vdss = -40V
    Rds = 25.8mOhm
    Id = -18A
    Re: NIKOS MOSFET replacements
    What is the footprint/package they are in, e.g. D2PAK, DPAK, SO8...
    • ecking767
      • Oct 2009
      • 492
      THEY are being sold on eBay, the place of origin is china, but what can you do if no one have them with-in the USA. You will have them in a couple of weeks.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Perhaps if you update your profile with country and mains voltage would help. There seems to be someone in canada who sells these?
          OK, checked it myself. Right, DPAK.
          N-FET: http://www.digikey.com/product-detai...SCT-ND/2074587
          P-FET: http://www.digikey.com/product-detai...SCT-ND/2798985
          I am actually using the first device in a design of mine for a high charge current battery charger. It's a cheap and powerful little fet.
          I am not sure you really need a 40A MOSFET, seems like overkill to me. Where are they used?
          • richr69
            • Jul 2010
            • 58
            Hi Thanks for all the replies. They (DPAK) are actually used on the secondary inverter board on a LCD TV I'm trying to repair (the manufacture escapes me right know). I did see them on e-bay, but I was hoping to find something equivalent w/a quicker delivery, and it appears digi-key has something equivalent.
            Again, thanks for the quick and helpful responses.
            • richr69
              • Jul 2010
              • 58
              Would the following 2 MOSFETs be also a sutable repalcement for the NIKOS MOSFETs. I know that these are ATPAK and the NIKOS are DPAK, but w/r to Vds, Id, and RDSon are they a match?
              Sanyo ATP106 P-Chan Mosfet (in place of NIKOS P2504EDG)
              Sanyo ATP206 N-CHan Mosfet (in place of NIKOS P1504BDG)
                ATPAK is a slightly different size, but they -should- work.
                • richr69
                  • Jul 2010
                  • 58
                  Thanks. I went ahead and ordered the parts from Digi-Key. Worst case I'm out 4 bucks.
                  • stupot1
                    • Mar 2013
                    • 10
                    Hi Rich,
                    I have a similar issue - tracking down some P1504BDG and P2504EDG MOSFETs.
                    These are for a slave inverter board out of an LG 42LG3000 LCD TV.
                    Did you have any luck with the Sanyo ATP106 and ATP206 MOSFETs?
                    Thanks,
                    Stuart.
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Nooy
                      VGA MOSfet permanently shorted and loss of MOSfet pad
                      by Nooy
                      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                      02-14-2024, 02:26 AM
                    • AppleLover123
                      Asus X712EA 3 volts after the first mosfet
                      by AppleLover123
                      Hey guys,
                      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                      Now i thought something...
                      12-15-2024, 07:49 AM
                    • MicroSMD Lab
                      by MicroSMD Lab
                      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                      01-10-2024, 06:36 AM
                    • Scotchmist
                      Asus GA502D keeps blowing mosfet
                      by Scotchmist
                      I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                      I have removed the mosfet and can run the laptop no problem
                      The MOSFET is FDPC5018SG
                      Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                      08-24-2024, 02:23 PM
