gray screen
  • ben800
    • 6
    • u.s.a.
    gray screen
    hello to all, i have an lg plasma tv(mod. 37lg10) and worked fine. was watching a movie and paused it,went to store, came back and now i have a grayish screen. it still has a picture and sound but a white or grayish screen background to it. any sollutions to this anyone?
    Re: gray screen
    I assume you've done the "obvious" and reset all picture settings to defaults?
    • ben800
      • 6
      • u.s.a.
      Re: gray screen
      i have done the reset to factory settings. just a few minutes ago it went to norm for about 1 second and back to the white and grayish screen again. tried to take a picture of it but didnt show right. the best way to describe it is like their is a white or gray cloud covering the picture. it goes to norm for a couple of seconds and the cloud comes back
        Re: gray screen
        We have seen this before and it turned out to be the T-con board, which is usually less than $30 to replace. That would be my suggestion.
        37LG10 is an LCD display. LG does not make any 37" plasmas, anyway.
        • ben800
          • 6
          • u.s.a.
          Re: gray screen
          thanks for the advice tom66. do u know where i can get them for less than $30?
            Re: gray screen
            First, you would need to open up your TV and locate the part number written on the board.
            If you post a picture of the inside of your TV we can locate the T-con for you.
            • ben800
              • 6
              • u.s.a.
              Re: gray screen
              i should have left that info for u when i had it open. duh.. i got 2 numbers off. i googled this one"37T03-C00" and it came up and this number here"T370XW02". LIKE I SAID, THANKS FOR THE HELP, appreciate it
                Re: gray screen
                Any pictures of the T-CON board, it can be as simple as blown surface mounted fuse on the T-CON board.
                • ben800
                  • 6
                  • u.s.a.
                  Re: gray screen
                  looks just like this one.
                    Re: gray screen
                    You can see WHITE surface mounted fuse on the left side of the bottom connector. You need to check (with the TV on) to see what DC voltage you have on both ends of the fuse, black probe of the DC voltmeter will be at the metal chassis, the red probe will be testing each end of the fuse for DC voltage, report what you find. Meter should be set to 20V scale.
                    • ben800
                      • 6
                      • u.s.a.
                      Re: gray screen
                      quick question; can anyone tell me where the inverter board(s) are located on the lg model 37lg10-um? And also, how do remove the metal casing off of the t-con board from same model.
                        Re: gray screen
                        The inverter boards will quite likely be on either side of the TV. There may only be one board.
                        The inverter is not the fault in this case as the inverter is only responsible for backlighting the display. Since the display is well lit it is not the fault.
                        • phil@philporter.com
                          • May 2013
                          • 113
                          Re: gray screen
                          I have same problem. Voltage showing 12.65 on top of fuse and 12.88 on bottom. Any suggestions?
                            Re: gray screen
                            Usually AS15F IC on t-con board.
                              • May 2013
                              • 113
                              Re: gray screen
                              Not sure what that means. Best to get a new T-con board? Only ones I find are used boards on e-bay pulled from "working TVs."
                                • May 2013
                                • 113
                                Re: gray screen
                                Google it. Got it. Thanks
                                  Re: gray screen
                                  If you can solder a chip on the board with 0.5mm pitch between leads, then replace the AS15F, otherwise, replace the board. The boards are pulls from TVs with cracked screens so receiving a dud is a possibility.
                                    • May 2013
                                    • 113
                                    Re: gray screen
                                    It's AF15U. I'm probably not that good at soldering. I'll look for a board. Thanks much!
                                    • sleeperjoe
                                      • Dec 2013
                                      Re: gray screen
                                      Hi Guys, new here.....
                                      I have one of the LG 37LG10 LCD TV's with the white screen or white clouding syndrome. Rumor has it from the above thread that either the T-Conn board or the AF15U or equivalent will do the job. Has anyone successfully fixed the syndrome by replacing the card or chip? If so where can one get (1) chip, searching comes up with vendors that will sell you numerous batches but nary a one that will sell just 1. I realize I can go with the card but I am good at soldering, even the small packages. Help is appreciated..... Regards; JOE
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Re: gray screen
                                        deleted wrong post
                                        • Mad_Science
                                          Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                          by Mad_Science
                                          I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                          03-01-2024, 05:05 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
