LG 50pj350 plasma not powering going to standby
  • cequil32
    • Dec 2012
    • 57
    Recently bought a 50pj350 on Craigslist and trying to make it work. This is my first plasma repair, been pretty successful with LCD but this seems to be giving me some trouble.
    After reading on here about others I found one of the 22 ohm resistors on the power supply open and replaced. However, when I connect ysus board I get no output. Disconnected I get the expected voltages.
    Any help with the ysus and zsus boards to know if they are bad? I did see a spark on the lower y driver when I was messing with some ribbon cables.
    Re: LG 50pj350 plasma not powering going to standby
    If you were messing with the ribbon cables while the set is live, you probably damaged the buffers. But you should be careful as there is over 200V on the sustain board at several amps.
    • Techstar
      Tv Restoration
      • Dec 2012
      • 122
      • United Kingdom.
      You must change both of the 22ohm resistors even if only one of them is open, use 7 watt types. Should you only change 1 of them the other often fails after a few weeks or months. The reason they fail is as the screen ages
      it draws more currrent through the resistors. Just thought i would mention it.
      • cequil32
        • Dec 2012
        • 57
        I think i was impatient and didnt let the caps go down before i messed with the cables.
        • cequil32
          • Dec 2012
          • 57
          I will keep that in mind and replace the other 22 ohm as well.
          • cequil32
            • Dec 2012
            • 57
            If i follow the training manual and have nothing on the power supply i get the expected vlltages but as soon as i plug the ysus board in there are no voltages and it goes into standby.
              Can you check the resistance between Vs and GND on the Y-sustain?
              • cequil32
                • Dec 2012
                • 57
                470 ohms between vs and ground
                  That is too low. Try powering the TV up with just one or the other buffer.
                  • cequil32
                    • Dec 2012
                    • 57
                    470 was with both y buffer boards removed.
                      Sorry, misunderstanding, please connect everything except the two buffers and power TV up, and see if it still goes back to standby.
                      • cequil32
                        • Dec 2012
                        • 57
                        Yes goes to standby
                          OK, now try it without the Y-sustain; if that fails then try the Z-sustain (board opposite Y-sustain)
                          • cequil32
                            • Dec 2012
                            • 57
                            With all other boards connected only the ysus board disconnected in the tip left the power supply stays on.
                              OK, so the fault is with the Y-sustain.
                              Do you know how to test the MOSFETs and IGBTs on it? One may be shorted, causing the problem. If you don't know how ask me and we can guide you through, but we need pictures of the board. You can also replace the whole board. Look for the part code, usually begins with EAX.
                              • cequil32
                                • Dec 2012
                                • 57
                                Do you need to take them out of the board to test?
                                • cequil32
                                  • Dec 2012
                                  • 57
                                  I ordered a ysus and both buffer boards. should i order the zsus and buffer as well?
                                    A ysus failing cannot possibly damage the zsus, as far as I am aware.
                                    There is no such thing as a zsus buffer.
                                    • cequil32
                                      • Dec 2012
                                      • 57
                                      The zsus looked like two parts and some on ebay were only selling one board, the bigger. that is why i assumed there was a buffer board.
                                        There is sometimes an extension board but it usually has no components on it, maybe a single capacitor, but its only purpose is EMI, i.e. reducing radio interference, it doesn't affect the performance of the display itself. The extension board is basically the same as a wire.
                                        • XCon
                                          LG 60PN6500 Plasma with standby, but won't power up.
                                          by XCon
                                          Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
                                          So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
                                          The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
                                          06-27-2025, 05:30 PM
                                        • UltimateNeutrino
                                          Samsung UE46F6400AWXXC not powering on, standby LED off
                                          by UltimateNeutrino
                                          Hello, since yesterday our Samsung UE46F6400AWXXC no longer powers on, with the standby LED off. It turned off when someone attempted to clean it, not sure if related. A few days ago, there was a similar issue, but it was solved after unplugging and replugging the power. Additionally, another user of this TV reported issues of the screen turning off randomly, which were solved changing the channel.
                                          I originally suspected the PSU, but if the mainboard is unplugged the PSU relay closes and the backlight turns on. It's only when the mainboard is connected that the relay doesn't close...
                                          12-01-2024, 02:47 PM
                                        • rju
                                          Samsung 60" Plasma TV, Blinking Standby LED
                                          by rju
                                          A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                                          Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                                          Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                                          07-21-2020, 05:23 AM
                                        • Willem01
                                          TV not powering on - with standby red –led flashing
                                          by Willem01
                                          Error – TV not powering on - with standby red –led flashing
                                          Model- LEDTV – 39T3500
                                          Power boarD - shg3206a-101h
                                          I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                          https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                          In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                          Unplugged the power connector on the board, I plugged the power cable in waited...
                                          02-27-2021, 08:23 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
