My LG 32LH20 LCD. Lines through picture, now no picture.
  • seifer666
    • Dec 2012
    • 9
    Tv has been working fine, suddenly while watching it, ive got a bunch of garbled lines through the picture, and through the menus as well.
    Stayed like this for awhile, progressively getting more periods of just black, and now its almost constantly black, randomly for a second or so ill get a flash of fully bright picture (with lines through it) backlight appears to be on all the time just from looking in the back of the tv
    any ideas on what I should be looking at? I dont see anything up with the power supply but that doesn't mean there isnt.
    I made a video, figured its worth a thousand pictures
    http://www.youtube.com/watch?v=NjTjs...ature=youtu.be
  • drpj23
    • May 2012
    • 528
    Re: My LG 32LH20 LCD. Lines through picture, now no picture.
    Include pictures of all the boards (power supply, main, and TCON) using manage attachments with ample lighting and high quality.
      I vote for a T-con issue, or the LVDS cable being loose.
      • seifer666
        • Dec 2012
        • 9
        OK here are the pics of the boards.
        When its 'running' there is one green LED lit up on the top right of the main board
        hope this helps
          Ooh, one of those non-replaceable T-CON that is integrated with the LCD panel assembly.
            It is a nice Sharp panel, but shame they did it like that. Wonder why LG used Sharp panel not one of their own?
            • seifer666
              • Dec 2012
              • 9
              anything I should be looking at or its definitely the Tcon and im screwed?
                Try reseating the cable going to the hidden T-con. Otherwise I would suspect the main board. Looking again at the video I'm not so sure it's the T-con at fault. But it's hard to call.
                • seifer666
                  • Dec 2012
                  • 9
                  reseating the LVDS has appeared to make no positive or negative effect.
                  a video of the current state would just be black, it doesnt want to show me anything even distorted picture.
                    The sound is good all the time?
                    Right now, the menus are also bad, for example volume control, brightness/contrast...?
                    • seifer666
                      • Dec 2012
                      • 9
                      the sound is fine yes.
                      the tv responds to the remote, ie volume, on/off, id assume menu still appears but i cant change any picture settings cause I cant see the menu.
                      edit: actually that time i got a bit of picture, it was very distorted and purple over everything including menu, but still most of the time no picture just black.
                        Did you try removing the cable and re-inserting it?
                        Try both ends too.
                        Just to make sure, it is the cable just above "INHIBIT COMPONENT PLACE FOR CABLE".
                        • seifer666
                          • Dec 2012
                          • 9
                          yeah both ends. the top side clips and the bottom onee slides in with the little lifty gate. made sure it was all the way in.
                          • gadinro
                            • Dec 2012
                            Hi there! With regard this LG 32LH20, with the set off unplug the connector for the control panel, and turn set on using the remote control; if problem still there turn it off;
                            unplug the IR connector for the remote control; turn set on using the power button on TV. Also check soldering side of power supply for any signs of components legs touching
                            the metal frame causing erratic symptoms like the ones you're having; if so, use good insulation there to solve this problem.
                            • seifer666
                              • Dec 2012
                              • 9
                              are you refering to the Tcon or the board that has the volume /channel buttons?
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • noisykid
                                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                by noisykid
                                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                12-30-2024, 07:15 PM
                              • srs
                                Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                                by srs
                                I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                                A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                                I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                                04-22-2023, 02:40 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
