55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
  • KongRubix
    • Dec 2012
    • 24
    Model type:
    VIERA TC-P55GT30
    One day my 55-inch plasma Viera HDTV just died. Tried to turn it back on and got the "seven red blinking lights of death."
    So today I pulled off the back and took pictures. I know I have a *very* shaky camera hand due to repetitive-strain problems, but I did the best I could by bracing the camera and took as many pics as I could of all the relevant hardware.
    Does anything stand out as obviously busted?
    1: http://i.imgur.com/AjFM8.jpg
    2: http://i.imgur.com/ytila.jpg
    3: http://i.imgur.com/N4yjU.jpg
    4: http://i.imgur.com/7hT0k.jpg
    5: http://i.imgur.com/1drct.jpg
    6: http://i.imgur.com/bPBVl.jpg
    7: http://i.imgur.com/E5Xys.jpg
    8: http://i.imgur.com/Peh76.jpg
    9: http://i.imgur.com/u3ADK.jpg
    10: http://i.imgur.com/bCCwf.jpg
    11: http://i.imgur.com/P8AcG.jpg
    12: http://i.imgur.com/T5exS.jpg
    13: http://i.imgur.com/ZSx71.jpg
    14: http://i.imgur.com/KRyWy.jpg
    15: http://i.imgur.com/CDLz6.jpg
    EDIT: I also found but unfortunately this did not seem to have info relevant to this issue (or a diagram of the hardware)
    EDIT: Found service manual
    Re: 55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
    Here is the service manual for your set.
    7 blinks:
    Driver SOS2
    (SU/SD Connector DET)
    (SU/SD Scan and Logic IC)
    This indicates an SU/SD fault; possibly a loose board connector, or a mis-seated connector leading to the panel.
    However, I have heard that the SU/SD boards on this model can sometimes be damaged by a bad plasma panel. In which case the fault would not be repairable...
    • KongRubix
      • Dec 2012
      • 24
      How would I know if it's a loose power board connector? I am not hardware-literate at all whatsoever. What do these connectors look like?
      (Thank you for the very fast response, btw)
      EDIT: With some Googling I also see it can be a SC-board failure (and based on the manual I think I know which board this is now) -- is this what you refer to with SU/SU faults?
        This photo:
        Tighten ALL of the screws on this board; they were shipped loose from the factory.
        Reseat that white connector (on both the upper and lower boards.)
        Did you TV have the infamous Panasonic "buzz" before it failed?
        If all of these fail, replace the SU and SD boards. However, take heed that it -could- be a defective panel.
        • KongRubix
          • Dec 2012
          • 24
          Originally posted by tom66
          This photo:
          I completely forgot to mention that but you're absolutely right; there was a rather loud buzz (louder than usual) for a few minutes before the TV died. I didn't think anything of it at the time until the TV died.
          When you say "upper and lower" boards do you mean the two connectors, one in the upper left and upper right of http://i.imgur.com/bCCwf.jpg ?
          • KongRubix
            • Dec 2012
            • 24
            Screwed everything down hard (most screws were OK, one or two were a bit loose)
              Yep, those, plus this one on the bottom of the image.
              The buzzing is related to the screws being loose. The loose screws may have damaged the SU/SD board (I do not know.)
              There will be a part number on the SU and SD boards; these are the boards that connect to the larger SC board via the white connectors. The part number will be like TNPAxxxx. What is the part #?
              7 blinks is unlikely to be SC failure, but I wouldn't entirely rule it out.
              • KongRubix
                • Dec 2012
                • 24
                I know you probably know all this, I'm posting this more so for my own sanity/mapping things out:
                http://i.imgur.com/Bnfh3.jpg
                To answer your question:
                SU: TNPA5340
                SD: TNPA5341
                Can't really pull out the connectors to re-plug them back in, still trying
                • KongRubix
                  • Dec 2012
                  • 24
                  Unhooked and reseated the white connectors on the SU/SD boards to SC board (SC41-SU41, SC46-SD46, SC42-SD42)
                  EDIT: Unplugged and replugged in the white thing with the white/brown cord
                  According to the manual it is the "connector" SC2.
                  Still can't figure out how to disconnect the "flexible cable" SC20. There's a thin black-top cap thing I can flip up but I don't want to pull on anything and tear it (no idea what I am doing) -- the cable itself doesn't seem to want to disconnect no matter what I do.
                    There's no need to reseat SC20 for the moment; the latch will hold it in place.
                    • KongRubix
                      • Dec 2012
                      • 24
                      Alright, so I've unhooked and re-seated the white connectors and SC2 -- do I put the powercord back in and test?
                        Give it a go.
                        It may be the SC board; according to a training manual for a later generation I found.
                        • KongRubix
                          • Dec 2012
                          • 24
                          When I try to turn it on, still the 7 red lights unfortunately (I can see from underneath)
                          Anyhow, when I turn it on:
                          http://i.imgur.com/NWx34.jpg
                          Area in red starts to hum a bit (normal sounding hum, like a TV turning on, can't tell which part exactly)
                          Hum stops, area in green clicks twice and then the red light on the front of the TV starts to blink.
                          Video:
                          http://www.youtube.com/watch?v=USCegu-r2ug
                          No idea if the sound is sufficient in this though. I'm just pressing the power button on the remote and then moving the camera close to the parts making the sounds.
                            Those all sound normal.
                            I'm not sure what to suggest without using an oscilloscope to check... I doubt you have one .
                            • KongRubix
                              • Dec 2012
                              • 24
                              Haha, indeed not.
                              I'm not sure if I should just consider this a lost cause and buy a new LED TV or something.
                              Was considering http://www.newegg.com/Product/Produc...82E16889102672
                                Avoid Samsung if you buy an LED TV (sorry... but Samsung make poor quality TVs that look pretty on the outside and have a great picture until they die 2 or 3 years later.) But to be honest, LED isn't all it cracked up to be anyway. The picture quality is only slightly better than a conventional LCD and probably worse than a good plasma; and the reliability is generally worse.
                                I'd personally recommend a plasma... maybe an LG if you don't want a Panasonic, even though Panasonic do have some of the best build quality, I'm seeing more and more issues with them. Not sure if it's because they're more popular, or just poorer built. They've definitely cut down to make TVs cheaper, but at least they still use good components and the build quality is second to none.
                                But I still think it's worth repairing.
                                • KongRubix
                                  • Dec 2012
                                  • 24
                                  Yeah that's why I bought this plasma (heard LED's were overrated, backlit LCD's), but it seems like the picture had better quality (even my plasma had a bit of "graininess" to it whereas the LED's looked sharp and bright).
                                  I'm worried about repairing; looking at
                                  http://hsindependance.hubpages.com/h...-blink-failure
                                  Seems awfully expensive (and I live here in Manhattan where getting someone to come out would be insanely pricey, on top of repairing the hardware)
                                    How old is the set?
                                    Panasonic are quite good with out of warranty repairs...
                                    The grainness of the display is due to the temporal and spatial dithering of the plasma panel, in order to add greyscale levels. The idea is from a normal 10ft distance the dithering isn't visible. Inspecting the panel at close will reveal this. Some cheaper LCDs do this too.
                                    My dad has a 6 yr old NEC 50" plasma (one of the last NEC plasmas made; I fixed it, was last user who shorted the speaker outputs on the rear, and blew up the amplifier board.) hich It looks better than my brother's new 46" Samsung smart-LED which is just too bright and colourful (unnatural -- everyone looks orange, etc.) YMMV.
                                    • KongRubix
                                      • Dec 2012
                                      • 24
                                      I bought this TV in mid-July 2011 (the set itself seems to have been made in June 2011 according to the back-sticker). Warranty has been expired for about 5 months. I had called in to the Panasonic support line, but they told me they couldn't repair since the warranty was up -- but they gave me the address/number of an independent repair service center about a mile away.
                                        Call them again, tell them you know about the 7 blinks issue, and say you want a repair or replacement. Just as that site says.
                                        17 months? For a 55" plasma? That is ridiculous and they know it. It is a manufacturing defect in the design which has led to the failure. A lot of the "GT" and "VT" series are dying. The older ones used to last 10 years+; they even had 5 year warranties on them for free.
                                        • bialag
                                          Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                          by bialag
                                          I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                          Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                          03-25-2025, 05:56 PM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • badcappo
                                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                                          by badcappo
                                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                          Diode type G972s6 - D101 with a short
                                          Mosfet 06N90E - Q301 shorted
                                          Fuse T5AH 250V - F103 blown
                                          Diode D301 shorted
                                          Relay DG1U-17VDC II - RL001 blown
                                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                          11-24-2024, 11:27 AM
                                        • domix
                                          43pus6401/12 - no picture, blinking ambi lights
                                          by domix
                                          Hello i have 43pus6401/12.
                                          After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
                                          Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
                                          Any common issue?
                                          Thanks...
                                          05-17-2022, 04:35 AM
                                        • crewdog
                                          Hp 15-dy2087nr white lights blinking
                                          by crewdog
                                          Board DAOP5HMB8F REV F
                                          Model OPSH
                                          No bios battery on board
                                          Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                                          Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                                          and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                                          Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                                          10-25-2023, 03:08 PM
