Samsung 50" Plasma HPT5044 No Picture
  • tieny
    • Feb 2012
    • 478
    Re: Samsung 50" Plasma HPT5044 No Picture
    Trying to figure out where to probe.
    I was looking at VR5500 on the service manual. The one on my board seems to be pointed at the opposite direction than the manual. Is this correct or should I change it to the correct postion stated in the manual?
      I highlighted on the image where to probe -- are you doing it without buffers? Sometimes a pin/hook is marked YOUT.
      For now you don't need to worry about Yfr as you will be able to use the scope to adjust it.
      • tieny
        • Feb 2012
        • 478
        Which picture? And yes I'm doing it without the buffers installed
          I posted here.
          https://www.badcaps.net/forum/showpo...8&postcount=77
          However, since you do not want buffers connected, see this image.
          • tieny
            • Feb 2012
            • 478
            So heres what I'm getting,
              So you are at 2V/div with 10X probe, meaning 20V/div.
              You should be seeing close to 200Vp-p across most of the waveform (the SUSTAIN portion) but are only seeing about 60Vp-p.
              This probably won't blow up the buffers (it's not shorted) but I also don't expect it to work.
                Try to set up scope so you see suggested pic on page 51. Same panel.
                http://www.tgohome.com/ServiceManual...&Search=Submit
                You can get a decent trigger in 60 Hz countries, like the US, by setting the SOURCE control to "LINE" in the HORIZONTAL section, then set timebase to 10ms/div and V/div to 50V. It will roll the trace slightly but is usually fine. Centre trace in middle such that with no connection the line is in the middle. Also, if you bought it from far away (~100mi or more), you need to adjust the trace rotation control to compensate for the change in Earth's magnetic field. Make sure VAR is in the CAL'd position on all controls (it should click when in the right position.) COUPLING for trigger should be AC for and channel must be DC.
                • tieny
                  • Feb 2012
                  • 478
                  Oh, I had the VAR set on the other side. (Tested a 3 Volt battery and didn't get the right settings for it to show on the scope)
                  I set it at 5V/div with a 10x probe and now I'm getting this, its about 200V peak to peak? So its working correctly?
                  On page 51, it says its for a 42" panel? I'm not finding the same components on my board.
                    Hmm, looks better. Everything major appears to be there. Try getting a closer shot on 2ms/div. It's a while since I've done this... need more practice... not enough time.
                    • tieny
                      • Feb 2012
                      • 478
                      Here it is on 2ms/div
                      This is the first time I've used a scope, still trying to figure out how each of these settings work .
                      What do you think you would you see, if lets say that cap that I'm measuring the scope across was bad? Just wondering.
                        Tweak the focus control until the image is clearer. Dropping the intensity control can help on older scopes.
                        It looks good though.
                        • tieny
                          • Feb 2012
                          • 478
                          Great! Heres after tweaking it a bit.
                          What would it look like if it were bad? Would it have spikes or dips in the waves where it doesn't reach or pass 200v p-p?
                          Okay, I want to check Yset and Yfr (VR5200 and VR5500), I noticed next to the adjustment points on the board theres always a cap. Is that where I should always place the probe to measure the waveforms?
                            Incorrect Yfr/Yrr just causes a poor picture (maldischarge.) I usually do not bother adjusting them with a scope because I just adjust it by looking at the image.
                            I see everything I am expecting. Can you zoom into the first subframe, near the first horizontal division? Drop the timebase to 200 or 500µs/div.
                            • tieny
                              • Feb 2012
                              • 478
                              I should be getting the buffers in the mail today, lets hope this works!
                              So heres zooming in. I had trouble trying to hold off it, I messed with the trigger level and hold off a bit but heres the best I got.
                              at 50us/div x10
                              http://www.youtube.com/watch?v=QVtiNTKu8GA
                              http://www.youtube.com/watch?v=jCPiW93Y_q0
                              at 20us/div x10
                              http://www.youtube.com/watch?v=ltCpjBKx3V8
                                It's kind of hard to see anything there because the trigger is rolling. Try using the trigger to latch on the Yfr/Yrr ramps?
                                • tieny
                                  • Feb 2012
                                  • 478
                                  Where do I probe for the Yfr/Yrr ramps?
                                    The main outputs have Yrr/Yfr superimposed -- they peak at Vs+Vrr, or about 350~400V.
                                    • tieny
                                      • Feb 2012
                                      • 478
                                      I think I got it, I had the triggering coupling source set on channel 2 when I was probing at channel 1.
                                      The trigger stopped rolling and heres what I got on 50 us and 20 us with the hold off set on minimum.
                                        Hmm, it looks good. I normally use my digital scope for this. I can single-shot capture it and zoom right in to the waveform to see each pulse.
                                        • ghiotom
                                          • Oct 2012
                                          • 41
                                          I don't know if having the buffers removed makes a difference, but here's a working 50" Samsung panel image. Your image looks more like the abnormal image on pg 54 referring to the Vsch voltage. It should be around -55V and is produced on the Ysus board. Again, it could be because the buffers are disconnected, but that voltage appears to be absent. Disregard those arrows on my image, they are pointing at the Vsetup peaks and were put there for a different thread.
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
