Samsung 50" Plasma HPT5044 No Picture
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung 50" Plasma HPT5044 No Picture
    Ya I have good Va and Vs.
    Since this is first time using this scope (any scope) could you point out where to probe the XSUS so I can verify the scopes functionality ? I have the waveforms from the SM posted earlier in the thread.
      Can you supply a picture of the X-main?
      • mmartell
        • Oct 2013
        • 3189
        D'oh not at home atm, watching sons baseball game
        I can dig one up from shopjimmy. Sec...
        • mmartell
          • Oct 2013
          • 3189
          There appears to be several boards, naturally, so will post a pic later on.
          Does the waveform, such as it is, imply the scope is adjusted properly ?
            The scope should be on 50 or 100V/div and about 2us/div to get a waveform like the one in my pictures.
            • mmartell
              • Oct 2013
              • 3189
              So I should push the knob in to rurn off the 5x magnification or does that not factor in ?
              • mmartell
                • Oct 2013
                • 3189
                Ok tom, messed around some more. You were right about having a dead ysus. See pic 1 for some insight into what I found when I went back in.
                Lol
                I think I managed to get a good shot. It seems to match up pretty well with the one in the SM. 2mSec and 50v/div so about +200v to -200v
                What you think ?
                  Done it myself plenty of times! Your Yset ramp looks clipped (beginning of the field), it should peak a little higher; can you try changing V/div on your scope up one notch to make sure it's not an artefact of the scope. Poor Yset won't kill buffers but the image will look poor.
                  • mmartell
                    • Oct 2013
                    • 3189
                    I tried already, can't seem to crunch it down any.
                    5v x 10x probe = 50v/div, right ? There is a "5x magnification" by pulling the CAL knob out so..
                    2v x 5x mag x 10x probe = 100v/div ? That should offer plenty of resolution for Yset.
                    Will try it again later.
                    Now that I think about it, what actually kills the buffers ? A sustained 200v ?
                      I really don't know what kills the buffers, but I suspect the root cause is related to Vsch being present whilst FG5V is not - however I honestly do not know for sure.
                      • mmartell
                        • Oct 2013
                        • 3189
                        My scope is rated at 275v. The Yset voltage looks like it could be approaching 300v. Would that clip the Yset spike and explain what I see in my image ?
                        The bottom of the waveform looks different as well...
                        • mmartell
                          • Oct 2013
                          • 3189
                          Ok the scope is rated at 250v, not 275v. And the magnification function is just that. So now I need a little help on working the scope.
                          The highest setting is 5v/div. I ASSUME the x10 probe gives me a max resolution of 50v/div. The grid in the Y axis is 8 high so 400v total. If I try to view the whole waveform (ground at middle of the screen) I clip whatever goes beyond that, Yset being one.
                          Is it possible to focus on say just the positive side of the waveform such that ground being at the bottom of the display I can view up to a theoretical +400v and thus capture the entire top of the wave ?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5091
                            • New Zealand
                            #193
                            You could try AC coupling to remove any DC offset, but if the AC component is that high anyway it won't make a difference
                            -David VanHorn
                            • mmartell
                              • Oct 2013
                              • 3189
                              So this scope is incapable of capturing the ysus output ? Ouch.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5091
                                • New Zealand
                                #195
                                Maybe you can make your own custom voltage divider and put it in series with the probe? I don't know if that would affect the quality of the signal though.
                                -David VanHorn
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Or buy another scope...
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    According to this document..
                                    my voltages at the test points near U5704 are off. My readings are all about 18v and that will KILL the buffers it says. Suspect U5706. Will check it for short not sure how else to verify its functionality.
                                      The number on your scope is the safe working limit. Your scope should be able to show a full waveform including offsets about 2 x from the maximum 1X input. e.g. at 5V/div, it should be able to read ±40V from centre by moving offset. A 10X will change this to ±400V which is sufficient for capturing VSET, so I suspect you do still have a problem with the Y-main.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        I'm sorry tom but what is an offset and how do I adjust it ? When looking at my captured waveform it looks like the scope has hit a hard limit at both the top and bottom of the form.
                                          On your scope, you have a V OFFSET control, or V POS, right? Adjust that.
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
