Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    • Bulgaria
    Re: Panasonic P50G20E
    I can not get into this menu ,is this the info button
      Yes, holding Volume DOWN on TV, then press that button three times, no luck?
      • Stanislav
        • Dec 2012
        • 135
        • Bulgaria
        and TV has no sound reduction ,Only through a combination of keys
        It comes only in info
          Can you try with the original board. I have a feeling something is wrong with the new board if it doesn't even recognise the side buttons.
          • Stanislav
            • Dec 2012
            • 135
            • Bulgaria
            old board can not be ON
            I'll wait a bit
              I thought it worked but shut down with old board? I'm a little lost.
              • Stanislav
                • Dec 2012
                • 135
                • Bulgaria
                #27
                Yes, if youON the old, works without problem, but now does not want
                  I would seriously suggest you attempt to reflow the board as it appears to be a common defect with both Panasonic and Samsung TVs.
                  • Stanislav
                    • Dec 2012
                    • 135
                    • Bulgaria
                    #29
                    Hello Tom
                    Please give me a reliable vendor for a new A Board, I still can not get my money back from the last Ebay seller.
                    If there is a reliable supplier of parts please tell me
                      I've used flattvparts before and no one else, because I've had good luck via eBay usually.
                      Raise a dispute on eBay and your money will usually be back in a few days.
                      • Stanislav
                        • Dec 2012
                        • 135
                        • Bulgaria
                        #31
                        Hi Tom
                        I do not know what to do,just got board from flatparts and guess
                        100% broken board ,TV turns on and after 10 seconds starts blinking 11 times
                          11 blinks is FAN error, check the fan connectors are properly installed.
                          • Stanislav
                            • Dec 2012
                            • 135
                            • Bulgaria
                            #33
                            Hi my friend
                            I'm not a fan in TV
                              No fans in this set at all? I thought Panasonic still used them in their sets?
                              SM:
                              http://www.tgohome.com/ServiceManual...&Search=Submit
                              Indeed, no fans...
                              I note there is no place for 11 blinks in this SM (i.e. no fan error), which means the board is most likely from a chassis which had fans in it, hence it is detecting fan error. Do you see any place where fan might connect? Was it from the same model? (Perhaps they removed the fans from the later versions...)
                              We may be able to trick it into thinking it has a fan.
                              • Stanislav
                                • Dec 2012
                                • 135
                                • Bulgaria
                                #35
                                Yes board is to model with fan
                                I do not see where have been involved.
                                There are several plugs but they are quite different from fan receptacle
                                  What model was it removed from, I can check SM for fan connector location (may be on PSU fed through PSU connector.)
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    • Bulgaria
                                    #37
                                    second,I found it hidden is but I saw her
                                    but to tell you I prefer to put fan
                                    • Stanislav
                                      • Dec 2012
                                      • 135
                                      • Bulgaria
                                      #38
                                      there is too warm and fan will be useful
                                        Installing a fan may be a good idea. You may be able to use a normal computer fan, or you can use the Panasonic original part, which people on eBay will probably sell.
                                        • Stanislav
                                          • Dec 2012
                                          • 135
                                          • Bulgaria
                                          #40
                                          well, but we you can put a resistor for to work until I buy and fan
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
