Panasonic P50G20E
    Re: Panasonic P50G20E
    Yes, if you tell me the model the board came from, I may be able to find out what resistor to use.
    • Stanislav
      • Dec 2012
      • 135
      #42
      it has the same number as my Board -It confuses me
      TNPH0838 A
        If you ordered it from Flattvparts, they would tell you what TV it came from.
        • Stanislav
          • Dec 2012
          • 135
          #44
          Tx p50v20b
            I have a training guide, but no SM:
            http://www.tgohome.com/ServiceManual...&Search=Submit
            So, can you show me the fan connector?
            • Stanislav
              • Dec 2012
              • 135
              #46
              • Stanislav
                • Dec 2012
                • 135
                #47
                Tom I mounted one fan but again turns off
                fan works but I can not measure the resistance of fan
                update
                this motor(fan) is brusless fan maybe that's why off
                  The yellow wire needs to stay low, I believe, on this set, a normal computer fan will pulse the yellow wire. Try disconnecting yellow and forcing it low with a 100~470 ohm resistor.
                  • Stanislav
                    • Dec 2012
                    • 135
                    #49
                    the fan is not PC ,it is dvd fan and have two wires red and blacк
                    definitely not suitable for this board
                      OK, you need to connect the unconnected terminal on connector to GND with 100~470 ohm to trick the board into thinking it has a fan and the fan is working well.
                      • Stanislav
                        • Dec 2012
                        • 135
                        #51
                        I'm sorry but I do not understand what you mean
                          You only connected two wires to that three pin connector right? On the pin you didn't connect, wire a 100 ohm to 470 ohm resistor to the ground wire, this should trick the TV into thinking the fan is always running.
                          • Stanislav
                            • Dec 2012
                            • 135
                            #53
                            NO pin connector there is 2 pin not 3 but fan no resistance between two wires
                              Can I see a closer picture of this connector?
                              • Stanislav
                                • Dec 2012
                                • 135
                                #55
                                  By its position, I'd say that's more likely to be an output for a subwoofer or speaker somewhere on the different version.
                                  Any other similar connectors?
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    #57
                                    No This is the only one who can look like a fan connectors.
                                    if you enlarge the image to the right of the CPU see caption
                                    • Stanislav
                                      • Dec 2012
                                      • 135
                                      #58
                                      http://www.datasheetarchive.com/LV4921-datasheet.html
                                      this is audio
                                        Look, the LV4921 is definitely an audio amplifier, and that connector is for the fan. Panasonic fan use three pins, with wires of red, black and yellow. It MAY be that the signal is routed through the power supply, SC board or SS board - it is on some models.
                                        • Stanislav
                                          • Dec 2012
                                          • 135
                                          #60
                                          only 3 pin socket on power board
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • dajoker
                                            Panasonic th-p50s10d - blinky red, SC board go boom
                                            by dajoker
                                            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                            I chased my way through the PSU, and a board, with no results.
                                            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                            I only have the right half of the picture.
                                            Left half is completely blank.
                                            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                            all the other voltage rails...
                                            09-24-2024, 04:39 AM
