Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    #121
    Re: Panasonic P50G20E
    What is external box
      A cable receiver, you know, like you'd use for a TV that didn't have cable built in.
      • Stanislav
        • Dec 2012
        • 135
        #123
        OK I understand . It really is suited for a different standard of digital TV.
        More importantly it works perfectly . I made a little improvement in new board ,I added another cooler
          Neat -- are you going to add fan? The SC and P boards are really the only ones which need good fan cooling. I seem to remember the G10 as being quite thin so cooling was restricted.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • dajoker
            Panasonic th-p50s10d - blinky red, SC board go boom
            by dajoker
            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
            I chased my way through the PSU, and a board, with no results.
            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
            I only have the right half of the picture.
            Left half is completely blank.
            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
            all the other voltage rails...
            09-24-2024, 04:39 AM
