Panasonic P50G20E
    Re: Panasonic P50G20E
    Yes, I looked into this, and I noticed P34 is missing on some of the G20 boards, but present on most V20 boards, the main difference being the absence of the fan on the G20.
    Can you take picture of bottom of PSU... we need to trace if any of those pins go to the main board.
    • Stanislav
      • Dec 2012
      • 135
      #62
      Ok
      One of the pin is connected to pin 14 of the P7
      And P7 goes to A board
      • Stanislav
        • Dec 2012
        • 135
        #63
        other pin is connected to pin12 of P7 middle pin is free
          Is one of those pins going to ground? (the screw hole is a good ground to test against)
          • Stanislav
            • Dec 2012
            • 135
            #65
            none goes to ground
              I looked it up and P34 is actually for the power switch, if present. Not for fan. Damn. Until I find the exact service manual for the V20, I'm stuck. May have to ask a friend.
              • tw2005
                • Oct 2011
                • 6458
                This is an Australian p50V20A manual.
                No fans in this and the A-board PCB is TNPH0845 part/version# TXN/A1LHUA50
                http://depositfiles.com/files/tt9hqm9t9
                  It may be the VT20 that has fans. (3D version.)
                  • tw2005
                    • Oct 2011
                    • 6458
                    I've got Canadian manual for TC-P50VT20 and can't see fans or SOS11 either.
                    A-board TNPH0835 vers#TXN/A1LSUUS
                      Service guide shows them though:
                      http://www.tgohome.com/ServiceManual...&Search=Submit
                      • tw2005
                        • Oct 2011
                        • 6458
                        Must be region specific then? Yes I can see the TH-P50VT20Z which I believe is New Zealand model so our Aussie one probably has also. Makes me wonder why not the v20 which I have.
                          VT = V-series Three-D.
                          V = V-series.
                          Driving a plasma panel with 3D contentrequires more brightness and faster switching (more power dissipation.)
                          • tw2005
                            • Oct 2011
                            • 6458
                            fair enough, that makes sense. Thanks.
                            In regards to the original board issue, I can't see if the exact version of each TNPH0838 A-boards he has been identified.
                            if I'm understanding the story he's purchased an A board from the UK?
                            Will a UK tuner work in his country?
                            I know that NZ and Aust have different frequency steps and range is also a little different.
                            I've tried it , not a single channel picked up. Boards were physically identical.
                              Most of Europe uses a very similar standard to Freeview DVB for over-the-air TV, which I believe is interoperable across all of Europe, but you could always use an external box for that in case that doesn't work.
                              Courtesy of a good friend, here is a VT20 service manual. I am going to wait at least a few days before posting it on SM site, per his request. Had to split it in two to get it up (woo, Python pyPDF), as it's a fringe bigger than 10MB.
                              • Stanislav
                                • Dec 2012
                                • 135
                                #75
                                My friends, the bad news is that this model has more than two fans ,that change and speed of rotation according to the operation of the TV
                                The other problem is that I can not open this TV to see where they are fans
                                The man said "never " Аnd the TV is mounted on a wall which further limits visual information for fans .
                                But certainly I see two fans on both sides
                                • Stanislav
                                  • Dec 2012
                                  • 135
                                  #76
                                  But most likely, fans have a separate board of management
                                  a new board that came has three connectors more than my
                                  1 is the subwoofer
                                  2 and 3 are perhaps the connection between A board and board fans.
                                    Looking at the schematic, the fan control is done through the "D" board on the VT20.
                                    You do not have a D board as yours has the functionality combined onto the A board.
                                    I'm guessing that some signal somewhere will be missing and there's little you can do about it, because it's not a simple on/off error.
                                    Are you sure it's from a V20? Because there's no way that the V20 could use fans.
                                    • Stanislav
                                      • Dec 2012
                                      • 135
                                      #78
                                      This is written on the plate that came with the board
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        #79
                                        Panasonic TX-P50V20B- Main AV -TNPH0838 - TXNA1LWUB
                                        This is written on the document that came with the board
                                          Is "TNPH0838" same as your original board?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • dajoker
                                            Panasonic th-p50s10d - blinky red, SC board go boom
                                            by dajoker
                                            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                            I chased my way through the PSU, and a board, with no results.
                                            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                            I only have the right half of the picture.
                                            Left half is completely blank.
                                            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                            all the other voltage rails...
                                            09-24-2024, 04:39 AM
