Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    #101
    Re: Panasonic P50G20E
      Have a look at the manual for the G20
      http://www.tgohome.com/ServiceManual...&Search=Submit
      Do any of the options match, or are they completely different?
      • Stanislav
        • Dec 2012
        • 135
        #103
        Tom, with your help I think it will solve the problem of fan
        outputs are 4 fans with 3 wires each. a power which is connected in parallel and 4 fans and yellow wire that is separate for each
        This is a picture of my board has no connector and it is clearly visible
          Very good, though this confuses me: Why would it be configured for fans if the connectors were not placed? Either you need to make a bridge between GND and fan signal line, or between fan line and +3.3V. I'd try the GND bridge first, try identifying which pins on that connector are ground. The thin trace is the fan signal line, probably.
          • Stanislav
            • Dec 2012
            • 135
            #105
            My English is bad sorry
            I wanted to say that the new board has connector,and the old is gone connector ,of it is clearly visible which are GND and which are "+
            "as +'m not sure but 4 are connected in parallel so it must be +
              Your English is far better than my Bulgarian! Of which I know about zero words...
              It makes more sense for V20 board to have connector on it. My tests above apply. Check voltages on each of the pins to locate the fan voltages. You could hook up a fan here if you want; it may end up being temperature controlled. Some other pins will be ground, plus there will be one extra for each fan, a signal line, which either must be grounded or connected to a positive supply. Try grounding those pins first with a blob of solder.
              • Stanislav
                • Dec 2012
                • 135
                #107
                OK
                I have a power from 6.960V Outputs pin for 4 fan
                Hello-здравей
                now you know something in Bulgarian
                  Do any pins have connection to ground. I just had a thought that if it uses speed control it might not show up, because it uses low-side switching. Can you mark on the image what pins show 6.96V?
                  • Stanislav
                    • Dec 2012
                    • 135
                    #109
                    other 4 pins go on the other side of the board each connected with a resistor
                      In which case, please make a jumper between each signal pin (neither GND nor 6.96V) and each GND pin, a bit of solder will be enough. If it still gives 11 blinks, it probably wants a positive signal.
                      • Stanislav
                        • Dec 2012
                        • 135
                        #111
                        well just add that the resistors are 4.7 k and they are related each other (if that makes any difference)
                          So if the grounding trick doesn't do it, we can probably wire them to the 7V (6.96V) safely, with no extra resistors, as assuming they go into ground or into a diode drop, they'll see maybe 7V, and dissipate at most 10mW (they are probably 0603 size, 63mW max.)
                          • Stanislav
                            • Dec 2012
                            • 135
                            #113
                            • Stanislav
                              • Dec 2012
                              • 135
                              #114
                              I can not tell you how grateful I am to you
                                Damn good TV, I hope you enjoy it
                                Adding a fan anyway?
                                • Stanislav
                                  • Dec 2012
                                  • 135
                                  #116
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Unbelievable, full marks for human intelligence on this one. will be a handy reference. Hats off guys
                                    • Stanislav
                                      • Dec 2012
                                      • 135
                                      #118
                                      My friends here are details on how to enter service menu
                                      this applies to all models -"G" and "V"
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        #119
                                        Hi my friend
                                        I dont have sound on cable TV. all other signal sources have sound but no cable tv
                                        I don't have the option to change the sound decoders
                                          This may be because the board is V20B... probably designed for different cable standard (maybe even Freesat, if in UK) than in rest of Europe... you may have to use an external box.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • dajoker
                                            Panasonic th-p50s10d - blinky red, SC board go boom
                                            by dajoker
                                            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                            I chased my way through the PSU, and a board, with no results.
                                            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                            I only have the right half of the picture.
                                            Left half is completely blank.
                                            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                            all the other voltage rails...
                                            09-24-2024, 04:39 AM
