Samsung LNT3242H 32" LCD TV, no picture but audio works- no component damage
    Re: Samsung LNT3242H 32" LCD TV, no picture but audio works- no component damage
    Please make sure your meter is on volts DC and the battery is OK, and see if you get 24V instead of 12V...
    • landen_michael77
      • May 2012
      • 57
      • united states
      I dont seem to be getting any power from the psu. Lights kick on for 2 seconds then off. I can only see them come on from a hole in the back of the screen. Not on the front at all.
        New LCD screens make it quite difficult to see the light emission from the screen, especially in a well lit room... technology improves. Seeing the backlight from the rear is good enough for us but if you want to confirm it then turn out all the lights and the glow will be more visible.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          thats a darfon inverter and one or more of the transformers are bad.
          check acme-sales.net for replacements.$3 ea.
          • landen_michael77
            • May 2012
            • 57
            • united states
            Is there any way I can test them to know for sure. I am capable of soildering. and using a multi meter. (somewhat). I like to learn though.
            • Mr Bill
              • Nov 2011
              • 648
              Set your meter to OHMS and put red probe on either 1 or 2 and black probe on 3 or 4. Record your readings. List them something like:
              Trasformer 1
              X.XXX
              X.XXX
              Transformer 2
              X.XXX
              X.XXX
              I'm betting kc8adu is spot on since darfon transformers are known for failure.
              • landen_michael77
                • May 2012
                • 57
                • united states
                #27
                1 & 3... OL
                2 & 4... 00.0
                all three of them have this same reaing. Also when I put my meter on the fuse by the cable coming into to the inverter it reads .000. I can post pics if nessesary.
                  Try measuring across 1-3 and 2-4 instead. Your meter should on 20kohms, if it is manually ranging.
                  • landen_michael77
                    • May 2012
                    • 57
                    • united states
                    #29
                    I was asking about these earlier.
                      Those are optocouplers, if the PSU is working, then they are fine.
                      • landen_michael77
                        • May 2012
                        • 57
                        • united states
                        #31
                        I dont think the power supply is working properly. How can I check it?
                          Have you tested the power supply outputs e.g 5V, 13V, 24V, are they good?
                            Transformer windings are pin 1 and 2, and 3 and 4. You may have to clean off the flux on the pins to get good contacts.
                            http://s807.photobucket.com/albums/y...t=DSC00191.jpg
                            http://s807.photobucket.com/albums/y...t=4002P710.jpg
                            • landen_michael77
                              • May 2012
                              • 57
                              • united states
                              #34
                              ok I get no readings when testing the 24v pins or the 5v pins. meter just keeps cycling through numbers. Is the light bulb method a "must"? But the standby light is lit on the front. Tv does turn on and make start up music.
                                So now you are saying that you do not see he backligts at the back side of the LCD panel any more? You were seeing it before which means the 24V and the 5V must have been present before, and now they all dead?
                                What is the power supply board P/N ? Is it the saem as the orignal OP, BN44-00156A?
                                • landen_michael77
                                  • May 2012
                                  • 57
                                  • united states
                                  #36
                                  The lights come on for only for 2 seconds. when i put my red on the 24v pin, and my black on one of the ground pins on the power supply I get nothing.....unless I am doing it wrong
                                    Can you show me the pciture? Try using the chassis for the ground instead. Is the board mounted on to the chassis?
                                    • landen_michael77
                                      • May 2012
                                      • 57
                                      • united states
                                      #38
                                      o
                                      • landen_michael77
                                        • May 2012
                                        • 57
                                        • united states
                                        #39
                                        1
                                          When you say "meter just bouncing around" tell us what that means, how (un)stable is it?
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
                                          • YellowJacket
                                            Samsung QE55Q60RAT - no picture
                                            by YellowJacket
                                            Hi friends,
                                            a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                            07-30-2024, 01:31 PM
