Take a chance on this one?
  • cliff_hootarski
    • Jul 2006
    • 411
    Vizio model XVT553SV LED LCD. On craigs list for $300. Owner claims the power supply and main board were replaced by an authorized Vizio repairman.
    In the process the picture became "messed up".
    What do you guys think?
    No way am I going to pay $300 for the set. It does look like parts are plentiful for the set.
    Re: Take a chance on this one?
    $50 at most.
      Looks like bad main board config?
      Most likely needs a reset -- but that can only be done from the service menu. Do Vizios even have service menus??
      • tw2005
        • Oct 2011
        • 6458
        I'd go with TOM. Definitely had 1 Plasma with weird stuff like yours although yours is really funky (and I just realised your talking LCD)and got that fully restored via the service menu and reset.
        • drpj23
          • May 2012
          • 528
          A little googling to the service mode
          Vizio Service Menu Method 1
          1. Turn The TV off.
          2. Press and hold the {CH +} & {CH -} buttons on the TV.
          3. Then press and release the {POWER} button on the TV.
          4. Release the {CH +} & {CH -} buttons.
          5. Now press the {MENU} button on the remote.
          6. You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
          7. Press and hold the {MENU} button for few seconds.
          8. The Service Menu will be displayed.
          Vizio Service Menu Method 2
          1. Turn The TV off.
          3. Then press and hold the {POWER} button on the TV.
          4. Keep all three buttons pressed for few seconds.
          Vizio Service Menu Method 3
          1. Press and hold the {EXIT} button on the remote for 3 seconds then release it.
          2. Then press the {1} {2} {3} buttons on the remote.
          3. To exit, press the {EXIT} button.
          GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
          VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
          VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
          Push "Menu" on remote and then push "Vol-" and "Input" on keypad
          GV46 / P50HDM / P50HDTV10A
          Press "Ch-" and "Ch+" buttons together once on keypad
          GV42 / L42 / VP42HDTV10A / VP50 / VX37
          Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
          P42
          Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
          VM60P
          Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
          The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
          GV47
          Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
          SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
          VO320EP8 / VO370M / VO420E / VP504 / VP505
          Press "Menu," and then press "2," "4," "8," "9."
          VA19 / VA22LF / VA220E / VA26
          Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
          VA320E / VA320M / VA370M / VT420M / VT470M
          Press "Menu" and then press the following combination: "1," "9," "9," "1"
          VW22 / VS370E
          Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
          • cliff_hootarski
            • Jul 2006
            • 411
            Will pick this up on Monday, will report back with any findings.
            • cliff_hootarski
              • Jul 2006
              • 411
              OK, finally got around to this one. Reset the ribbon cable from the main board to the Tcon, no change.
              Replaced Tcon board, no change.
              Changed Power Supply, still no change.
              Decided to give the ribbon cable to the Tcon board a little more attention.
              Thoroughly cleaned the cable, reseated, and BINGO....Fixed.
              I purchased the Tcon, Pwr Supply beforehand, just in case I needed them.
              I will be keeping this TV and since it is a Vizio, I'll probably need both these boards in the future.
              I paid $150 for the TV (the most I have ever paid for a broken TV) and another $77 for the other two boards.
              • twbranch
                Mad Nerd
                • Oct 2012
                • 153
                $300? Nope! Got to leave some meat on the bone if you plan to resell it!
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • howardc64
                  Vizio SmartCast TV software bug that looks like hardware
                  by howardc64
                  Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                  It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                  11-16-2024, 05:17 PM
