Visio VO370m - 1 second backlight
  • ahickman
    • Jan 2012
    • 233
    Re: Visio VO370m - 1 second backlight
    Thank you.
    • ahickman
      • Jan 2012
      • 233
      I asked them to post a picture or send me a picture to verify pinouts. Looks like the TM-10160 may also be a substitute.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        I dont think so - the pinout is good but the secondary resistance is only 950ohms
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • canadaboy25
          LG Flatron 24EN33TA No Backlight When Cold
          by canadaboy25
          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
          03-07-2023, 12:23 AM
        • Cornito
          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
          by Cornito
          Hello Team,
          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
          08-08-2024, 08:09 AM
