Vizio 32 inch (VA320M) Eco 1080p black screen
  • KuDaH
    • Nov 2012
    • 22
    • united states
    Eco 1080p 32 inch Vizio
    Model # VA320M
    Picture went black, sound too. As the unit is powered on the vizio logo on the bottom goes from Amber to white. The Vizio logo on the screen pops up (black and white splash screen) and looks perfect. It stays on for about 5 or six seconds as usual, then goes black, this is all normal. From that point on I get nothing. Menu button does not produce an on screen menu, and input button does not display input selections. Video input from Direct TV is black and no sound. Direct TV box workls good on alternate TV.
    Took the back off the TV. All the CAPS look good on three out of the four boards. Fourth board has no CAPS, Learning here myself... the power supply board voltages are ok on the outputs marked.. 24V 5V 12V and so on. I am not versed in advanced electronics but know the basics.
    The inverter board looks good with its caps, all parts look good to me.
    The small control board looks ok too.
    The "Motherboard" I call it with all the inputs for audio and video also looks ok to me.
    The TV worked fine, had a few times when it went black, but a restart fixed it. Now / No / Go.
    Any help would be appreciated. already bought a new TV but would like to get this fixed.
    Re: Vizio 32 inch (VA320M) Eco 1080p black screen
    "the power supply board voltages are ok on the outputs marked.. 24V 5V 12V and so on."
    OK, do you have Digital meter? We need to see what voltage you have on those pins when you turn the TV on.
    • KuDaH
      • Nov 2012
      • 22
      • united states
      The voltages on those pins correspond to the voltage marked on the board. I checked them with the multimeter...all look good. I did not check the "ground" pins. Also unsoldered one lead on the fuses on the power supply board and checked continuity on them.. believe there are 5.. all read good.
        Is there any label on the pin with BL_0N, Dim, or 'A', 'B'? I am looking to see if the BL_ON (Backlights On) signal from the main board goes away or not. By the way are the backlights still on?
        • KuDaH
          • Nov 2012
          • 22
          • united states
          There is a white wire on the output side of the power supply leading to the inverter. (that is the board with the side lights, I think is is called the inverter) its the big board that runs from top to bottom onthe left in the picture. The white wire says "On / Off" and yes the lamps shut off after the initial splash screen.
          Good point, If that is the power to the lights.
          I imagine I should get a reading off that and see if it is correct.
          How do I do that?
            This one doesn't use an inverter.
            But you said you lost sound?
            Can you get close up of the power connector from PSU to main board?
            • KuDaH
              • Nov 2012
              • 22
              • united states
              Thanks, and yes loss sound too.
              here is the powersupply close up
              here is a close up of the connector on the power supply to the main board
              here is a pic of the main board connection from the power supply
              this should help
                OK, there's a pin marked 5V. Connect your multimeter's negative lead (black) to the chassis -- this is ground. What voltage do you measure on the 5V wire -- any one will do (not important which.) Probe the slightly exposed metal contact around the wire.
                • KuDaH
                  • Nov 2012
                  • 22
                  • united states
                  Done,
                  4.98 dcV on one
                  4.97dcV on the other
                    OK, good standby voltage. Can you check 24V? If it drops out just as the Vizio logo goes away, this might be the problem.
                    • KuDaH
                      • Nov 2012
                      • 22
                      • united states
                      Both 24v pins stay at 24v afterthe splash screen cycles and the lights go out.
                        OK, now can I get a picture of the connector going to the inverter. We need to check if BL ON is going out. If it is, the main board is turning the backlights off. Vizios have lots and lots of problems with main board faults. I don't even work on them (US only) and I know that just from reading on here...
                        • KuDaH
                          • Nov 2012
                          • 22
                          • united states
                          Picture of connector leading to inverter
                          sorry bad post here
                          • KuDaH
                            • Nov 2012
                            • 22
                            • united states
                              OK, on this model it is ON/OFF, does the voltage change as the backlight switches off?
                              • KuDaH
                                • Nov 2012
                                • 22
                                • united states
                                on/off lead readings...
                                .2mv TV off
                                4.92 V TV on
                                93.7mv after splash screen dissappears and lights go out.
                                  So the problem is on the main board. What a surprise...
                                  Is it possible to remove that metal shield covering the inputs on the main board?
                                  When you do that, follow retiredcaps excellent guide on testing your voltage regulators.
                                  https://www.badcaps.net/forum/showpo...29&postcount=1
                                  • KuDaH
                                    • Nov 2012
                                    • 22
                                    • united states
                                    Im confused.
                                    the on/off wire comes from the power supply and goes to the inverter. it gets its signal from the main board through the power supply?
                                      Yes, it is a common arrangement. The signal is passed from the main board, through the power supply, to the inverter, to reduce the need for more cabling looms (which costs money...) The power supply just has a direct connection between both ends. Same for DIM.
                                      • KuDaH
                                        • Nov 2012
                                        • 22
                                        • united states
                                        thats why I am asking someone who knows what they are talking about.
                                        I bever would have thought that. Thanks. gonna check out that link now. shield is off the main board now.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • paqman
                                          Vizio M60-C3 black screen
                                          by paqman
                                          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                                          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                                          03-02-2024, 04:37 PM
