LG 50PQ6000 unstable 5v standby
    Re: LG 50PQ6000 unstable 5v standby
    I think modding one in would lead to poorer performance.
    A diode's current rating is determined by both the size of the die (high current density destroys the device) but MAINLY decided by the amount of heat it can remove (0.6V at 3A ~ 1.8W, must be able to get rid of this without overheating.)
    • Baileybum1234
      • Sep 2012
      • 245
      Use the 5v and add a mini pc fan directed at the diode? Maybe.
      Repaired: LG50PQ6000
        Might help, but a mini fan will screeeeeeam in standby mode.
        • Baileybum1234
          • Sep 2012
          • 245
          Ok back at home now, I was using the smart phone while working away its some what challenging.
          So is there a way to test the control board to see if some component is faulty and pulling too mutch current through that diode and making it go O/C? OR am I totally wrong with that theory do you think?
            No, I doubt that's the issue. The diode is simply running too hot.
            • Baileybum1234
              • Sep 2012
              • 245
              ok then maybe the replacement I found had a slightly different spec to the original. I will have a proper look later online.
                Yeah, it was 150V rated instead of 200V. The new one is 200V.
                • Baileybum1234
                  • Sep 2012
                  • 245
                  So I wounder what would happen if I put one of these in instead?
                  Manufacturer's Part Number: SF47G R0
                  4A 500V 35ns Super Fast Rectifier Glass Passivated
                    It's not a schottky diode (low loss type), but it may work.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      If the original shottky diode got hot and fried, then that diode will certainly fry faster!
                      tom66, why you think it would lead to poorer performance? A heatsink could be added to the TO-220 device also, to keep it cooler. I don't understand how that would lead to poorer performance :S
                      Muh-soggy-knee
                        Because a TO220 device with a crappy heatsink is going to be just as limited as that package. Maybe it would run a little cooler, but the correct solution is to find the right diode.
                        • Baileybum1234
                          • Sep 2012
                          • 245
                          I thought I found the right diode when I fitted the VSB3200 and it fried :0/
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Ah, so you mean like a fast enough recovery time, reverse current, and capacitance?
                            The original diode, a VSB3200 claims that it is a high-efficiency diode (VF=0.63V) - the SMPS is designed terribly because of that 'high-efficiency' diode overheating!
                            Really should get a new test diode, and then scope the diode, to see if it really needs to be a 200v diode.
                            Muh-soggy-knee
                            • Baileybum1234
                              • Sep 2012
                              • 245
                              Shame I have one more VSB3200 test diode but no scope. Guess it cant be done on a DVM?
                                It's definitely a VSB3200? Not incorrect part? CHS have done that to me before!!!
                                • Baileybum1234
                                  • Sep 2012
                                  • 245
                                  Well if I look at the original its markings are:
                                  VSB3200
                                  M944A
                                  and the replacement was:
                                  SB3200
                                  1142
                                  (eventhough the CHS label says: VSB3200 DIODE GENERAL) You could be right here Tom.
                                    It looks to be similar.
                                    Odd that it failed quicker than the 150V diode!
                                    • Baileybum1234
                                      • Sep 2012
                                      • 245
                                      Im still not sure where the 150v diode came in (confused.com)? I never used a 150v diode just went straight to the (what I thought was a VSB3200) SB3200 as a replacement thinking it would be a better option?
                                      • Baileybum1234
                                        • Sep 2012
                                        • 245
                                        I wounder if I should have a moan at CHS.
                                          I thought I linked you to the 150V part on Farnell?
                                          I would think that if the original diode lasted -X- years then their replacement can also be expected to last -X- years.
                                          So I would think the diode isn't a directly substitutable part, you need to find a VSB3200 not an SB3200.
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • reessi
                                            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                            by reessi
                                            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                            Years ago it had some bulging caps...
                                            04-26-2021, 11:42 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
