LG 50PQ6000 unstable 5v standby
  • Baileybum1234
    • Sep 2012
    • 245
    Re: LG 50PQ6000 unstable 5v standby
    Originally posted by ben7
    Most DVM's [that I know of] don't measure capacitance above 10uF.
    What is the reading of the diodes, when you took D351 out?
    P.S. We are both on different paths (me and tom66), feels awkward, doesn't it?
    0.22v one way and 0v the other on both diodes in the component. (Diode removed from board and tested with DVM on diode test)
    To be honest I dont the two paths its all amazing help I have had more ideas/suggestions this evening that the last 4 weeks of doing it on my tod.
    Repaired: LG50PQ6000
      Have you tested D352? Looks like it's got really hot. If it were leaky, it might stop the PSU from reaching full 5V.
      • Baileybum1234
        • Sep 2012
        • 245
        Ok I will test D352 tomorrow after work I really need to get my head down I have a fair bit of driving to do tomorrow with an early start.
        Thanks for your help this evening guys its been great and looking forward to tomorrow evening now.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          This is so strange.
          Are you finding that BOTH diodes measure 0.22 in the forward direction (plus probe on diode anode, and minus probe on cathode), and BOTH read 0 in the reverse direction?
          Or, is your meter one of those cheapo meters? I've never heard of a diode being shorted in one direction. Are you sure your meter isn't saying 'OL'?
          Muh-soggy-knee
          • Baileybum1234
            • Sep 2012
            • 245
            This is so strange.
            Hi ben,
            Sorry was getting late for me last night.
            Right the cathode is the middle pin on the IC and with the red probe on the middle pin and the black on either of the outer pins I get .0L
            Witht the black probe on the cathode and the red probe on either of the outer pins I get 0.215v.
            • Baileybum1234
              • Sep 2012
              • 245
              D352 id 0.00v in both directions on diode test. Im guessing this is bad?
                Yep! There's your fault... It looks like it got very hot, probably run at above its maximum current due to poor design.
                • Baileybum1234
                  • Sep 2012
                  • 245
                  Ok reality check.
                  Would it of killed anything else on its way out do you think? annnnddddd where would I find one.
                  Thanks for your help and ben7's I was going mad round and round in circules before I came on here.
                    I doubt it. Usually when a diode fails (short almost always), the power supply goes right into protection mode, hence the low 5V... and it may explain the 12V measuring 0V, as it -might- be on the 12V rail.
                    There is a part # on the diode. You may have to remove it to read it. Then you can find a replacement.
                    • Baileybum1234
                      • Sep 2012
                      • 245
                      Well done tom66 good fault finding skilles there mate.
                      Its a VSB3200 M944A. Is it supposed to be regulating the input to the regulator?
                        I don't know what that diode does but it's bloody hard to get hold of.
                        It's a 200V, 3A schottky diode. Special type of low-loss diode.
                          Highest I can find is 150V.
                          http://uk.farnell.com/stmicroelectro...-3a/dp/1702811
                          This may be an "install it, see if it works, and if it fails, source the 200V one" job. I doubt that diode sees 200V transients on the 12V output. Probably 3-4x that in reverse at most. But I didn't design this PSU, so I don't know.
                          • Baileybum1234
                            • Sep 2012
                            • 245
                            Blimey a rare one?
                            I think I might have the TV fixing bug. Have yet to see if this is the fix but I really enjoyed working around the board and learnt alot.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Good job folks!
                              LOL, I knew something was wrong, you said zero volts, instead of OL. As far as I know, a diode cant go shorted in one direction xD
                              Glad you kept pushing through, as there are people who come here wanting help, and they just loose interest, or think it is too hard.
                              -Ben
                              Muh-soggy-knee
                              • Baileybum1234
                                • Sep 2012
                                • 245
                                Its a fast acting diode with low voltage drop between anode & cathode often used in reverse protection and/or voltage clamping well goto love the net.
                                • Baileybum1234
                                  • Sep 2012
                                  • 245
                                  Good job folks!
                                  -Ben
                                  I have been there many times with this . I guess its the fact im interested in electronics that keeps me going. I just really appreciated the fact I could bounce ideas of some people who are obviously into it too it can help sooo mutch.
                                  • Baileybum1234
                                    • Sep 2012
                                    • 245
                                    Good job folks!
                                    -Ben
                                    Thanks for your input ben it really was appreciated also
                                    • Baileybum1234
                                      • Sep 2012
                                      • 245
                                      20 quid minimum order hummmmmmmm what else do I need
                                        0.39 ohm resistor (just in case) and capacitors.
                                        There is a Farnell trade counter here in Leeds. It has a £5 minimum order. If I'm going up there soon, I could get you the items.
                                        • Baileybum1234
                                          • Sep 2012
                                          • 245
                                          thanks for the very kind offer Tom but I dont think I could wait that long.
                                          Any one ever used this place?
                                          http://www.donberg.co.uk/
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • reessi
                                            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                            by reessi
                                            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                            Years ago it had some bulging caps...
                                            04-26-2021, 11:42 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
