LG 50PQ6000 unstable 5v standby
  • Baileybum1234
    • Sep 2012
    • 245
    Re: LG 50PQ6000 unstable 5v standby
    Looked at my only old PC PSU and there isnt one.
    Found this online though?
    Simple-Set your analog meter to X 10 K ohm range. Black probe to pin1 and red probe to pin 2 and 3 (must have readings) then black probe to pin 2 and red probe to pin 1 and 3 (must have readings). If black probe to pin 3 and red probe to pin 1 and 2-it should have no reading. If there is a reading then it is consider shorted. How acurate is this test? It is 90 over percent. That means, if you still suspicious about the reading then the only way is to direct replace the component and retest the smps again. This component is quite cheap and easily get from those used electronic board especially the SMPS that have the optoisolator in it.
    Credit to jestineyoung.com
    Repaired: LG50PQ6000
      Not useful.
      Only tests for leaky/short not failing reference.
      Why don't you follow this thread - I'm helping heavymachines out with possible same issue:
      https://www.badcaps.net/forum/showth...=24304&page=10
      • Baileybum1234
        • Sep 2012
        • 245
        Agreed didnt help me at all.
        • Baileybum1234
          • Sep 2012
          • 245
          Originally posted by tom66
          Not useful.
          Cool will do thanks
          • Baileybum1234
            • Sep 2012
            • 245
            Cool will do thanks
            The link brought me back to this thread!
              I mean here
              https://www.badcaps.net/forum/showth...t=25670&page=4
              • Baileybum1234
                • Sep 2012
                • 245
                Cooleo! Cheers
                • Baileybum1234
                  • Sep 2012
                  • 245
                  I think I will get some in stock they seam a useful part to have in the draw.
                  Could you please tell me if the KIA431A is the same as the TL431A?
                  Data sheets below:
                  Ebay has some TL431A's easy to obtain thats all.
                  I have had a look and a few of the important looking numbers look close but not exact.
                    They appear to be compatible.
                    • Baileybum1234
                      • Sep 2012
                      • 245
                      Thanks Tom
                      • Baileybum1234
                        • Sep 2012
                        • 245
                        I replaced 4 x TL431 but still a low stand by voltage.
                        I was lookng at this resistor and it was sutch a low resistance I couldnt check it??
                        Ps. have circuled a few bits.
                          Whats with that diode looks brown/burnt?
                          • Baileybum1234
                            • Sep 2012
                            • 245
                            Just been replaced with a new 1N4007. The original was shorted.
                              The old one was as 1N4007? Or was it UF4007?
                              • Baileybum1234
                                • Sep 2012
                                • 245
                                Give me a min I will double check.
                                • Baileybum1234
                                  • Sep 2012
                                  • 245
                                  OK the original was an IN4007S 943 OR 1N4007S 943
                                  Its very hard to read and I can find data sheets on them both. :/
                                  The replacement is a: Silicon Rectifier Diode 1N4007 1 A 1000 V
                                    It would be 1N4007S not IN4007S.
                                    But anyway that's the right part.
                                    Is the new part shorted in any way?
                                    Does it measure 4.4V with main board unplugged?
                                    • Baileybum1234
                                      • Sep 2012
                                      • 245
                                      New 1N4007 seams ok with diode test on DVM.
                                      4.45vDC board unplugged.
                                        OK, can you buy beg borrow or steal a 10 ohm 5W resistor? We need to see if P/S is stable under load.
                                        • Baileybum1234
                                          • Sep 2012
                                          • 245
                                          I just happen to have 2 x 10 ohm 3w resistors in my hand.
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • reessi
                                            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                            by reessi
                                            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                            Years ago it had some bulging caps...
                                            04-26-2021, 11:42 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
