LG 50PQ6000 unstable 5v standby
    Re: LG 50PQ6000 unstable 5v standby
    £19.50 is cheap enough that I would not normally repair a board... unless it was super simple like bad caps / shorted diode etc.
    • Baileybum1234
      • Sep 2012
      • 245
      Well all the other PSU boards for sale were 40-70 and I have lernt looking around on here and fault finding around the board its been an interesting exercise.
      I will swap out the IC just to see if it fixes the standby 5V for my own curiosity.
      Tomm if I was to use the new boards do I need to be aware of anything like adjustments? I have seen VS and VC adjustments? am I correct?
      Repaired: LG50PQ6000
        Set Vs and Va to your panel sticker ratings, that's all you need to do.
        • Baileybum1234
          • Sep 2012
          • 245
          cool
          • Baileybum1234
            • Sep 2012
            • 245
            Well work this one out and follow if you can:
            Recieved the replacement PSU and control board and fitted them to the TV.
            Fired it up and the psu board relays whent into clicking overdrive. Measured 4.7V standby.
            Thought what the heck so fitted the new PSU and my old control board. Measured 0v standby.
            Looked at the PSU board it had a crack across 4 tracks in a corner probably from the postal service so repaired them. Thanks royal mail!
            Fitted it back with the new controller. No fire up and 0v standby.
            Very quickly noticed the Schottky diode on the 5v line was showing bad readings had a spare and replaced it. Standby now 5.2V.
            All works fine now. Forgot to adjust VS and VA in all the fuss.
            I wounder if my old control board was faulty after all that and blowing the PSU 5V standby line?
            Also if I dont adjust VS and VA after fitting the new control and PSU board will it have any detrimental effect on things longer term?
            and by the way thanks for the help Tom your a real asset to this forum. :0)
              A poor Vs will cause a picture which has darker stuck pixels on it, you need to adjust it to the panel sticker.
              A very high Va can damage the panel and must be set correctly.
              • Baileybum1234
                • Sep 2012
                • 245
                Back off the wall again
                • alwaysfresh
                  • Jan 2015
                  • 12
                  #268
                  did you manage to solve the problem of the old PSU?
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
                  • psssst
                    Yamaha TSX 120 Standby Problem
                    by psssst
                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                    03-01-2024, 07:25 AM
                  • reessi
                    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                    by reessi
                    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                    Years ago it had some bulging caps...
                    04-26-2021, 11:42 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
