Replaced T-con board and now getting vertical lines
  • sr9800
    replied
    Re: Replaced T-con board and now getting vertical lines
    yes, it is correct ...
    do you think i got a faulty t-con board ?
    or is it possible that the tv has a faulty panel or main board ?
    replied
    Did you match the P/N on the barcode, not as printed on the board.
  • sr9800
    replied
    Yes, the same exact t-con...
    i am sure...
    replied
    Was the T-con an exact match?
  • sr9800
    started a topic Replaced T-con board and now getting vertical lines
    I have a Sony bravia KDL46VL160, first problem was a blank screen with sound.
    When bought and replaced the t-con board, coloured vertical lines are as shown in the picture
    What do you all think is the problem ?
    Thanks for the help...
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • Falki
    Colorful LCD Vertical Lines on Samsung ue55es8090
    by Falki
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    A similar issue has been posted as well but also with no actual response ...
    08-12-2025, 04:19 AM
  • gpo23
    Sony KDL-40V3000 - Vertical lines
    by gpo23
    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
    With the new t-con the color are good but there are vertical lines on all the screen :
    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
    Is there a way to fix the vertical lines on the new t-con ?
    Thank you for your help
    gpo23...
    10-04-2023, 09:11 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
