Polaroid FLM-3732 Power On/Off
  • dragon16
    • Nov 2012
    • 5
    Hello all,
    My TV has failed, and I'm hoping that you good folks could offer some advice.
    Here's the skinny:
    The TV is a Polaroid FLM-3732 that I bought new 6 years ago or so. It never had any problem at all prior to this failure.
    The symptom: One evening after a couple hours of constant operation, it turned off. No standby LED at all. Disconnecting from AC power for 10 seconds or so, then reconnecting would get the standby LED back on, but pressing the power button would only result in a momentary change of the LED from red to blue, then it would go dark again.
    I opened it up on the bench, so that I could check power supply rail voltages, etc. The +5VSB (standby, I assume) is coming up on power up, and looks stable and clean. When the power button is pressed, the +24, +12, and +5.1 rails come up, and appear to be stable - but maybe slightly low. A moment later there is a faint tick, and all rails drop to 0, including +5VSB. This is repeatable by removing AC power for a few seconds.
    I also found three capacitors bulging. They were the two 1000uF/10v which are in parallel on the +5VSB circuit, and the 1000uF/35v which is on the 24v rail. I replaced them, and in the interest of eliminating any additional capacitor trouble, I also replaced all other electrolytics on the board with the exception of the two 100uF/450v bulk caps, which I tested with a capacitance meter, and both showed dead-on. The caps that I used for replacements are ones that we had in stock at work, so some are a bit higher voltage than the originals, but identical capacitance. I didn't think that could possibly hurt anything. The brands are United Chemicon LXY and KMG, and Illinois Capacitor CKHM.
    After recapping, I reinstalled the power supply, only to see the same symptom as before.
    Having read another thread here about a similar problem with an identical power supply, I tested all diodes with a good Fluke multimeter's diode check function. No problems here as far as I can tell. I also checked the junctions of all FETs. They look good, too. I can't see any markings on the smaller transistors on the back of the board, and thus I'm not sure which pin is which for testing.
    After checking all of this, mostly out of frustration I put the supply back into the TV again, and tried a few times to get it to power on. Surprisingly, after a few tries, it did! I was able to turn it on and off with the power button a few times until I let it set in the "off" state for a few minutes, then back to the original symptom. I also noticed that after this bit of foolery, the heat sink to which the main two switching FETs are attached became very hot to the touch, and a small amount of smoke was coming from the toroid inductor that is mounted under a different heat sink (the one that the bridge is attached to).
    I brought the power supply to work with me, where I have access to much better tools. I powered up the board with no load attached, and activated the other rails by applying a 3.2k Ohm resistor from +5VSB to STB. All rails came up, and looked nice and clean on the oscilloscope, but I didn't leave it on for very long, as I didn't want to overheat anything any more than necessary.
    This is where I stand now. If you've read this whole novel, I'd like to thank you. I know it's long, but there's no point in asking for help if I'm not going to give you all of the pertinent information, right? Please don't hesitate to let me know if I haven't been clear about something, of if I've left out important info.
    Any suggestions are most welcome!
    Pictures will follow shortly.
    Thanks,
    Troy
  • dragon16
    • Nov 2012
    • 5
    Re: Polaroid FLM-3732 Power On/Off
    Here is a pic showing the specific components that I tried to describe above.
    • Version 7
      • Nov 2012
      • 12
      Hey Troy
      I'm pretty new to this but one of the things I've read alot on here was the importance of matching your capacitors with the correct type. From what I understand, these power supplies require low esr / low impediance capacitors on the output side (possibly throughout) of the power supply.
      The Chemicon LXY is low impedance and recommended for power supply output but the KMG is just a general purpose cap.
      Here is a link to their capacitor group chart:
      The Illinoise CHKM cap is also a general purpose cap as well.
      https://cdn.badcaps-static.com/pdfs/...60e0cb0665.pdf
      From what I've read, the general purpose caps wont work as a replacement for a low esr / impediance cap.
      I'll be watching your thread to see what you come up with - working on a similar problem....
      Kevin
      • dragon16
        • Nov 2012
        • 5
        Hey Kevin,
        You know, the low ESR thing crossed my mind, but I was under the impression that a cap with too high of an ESR would only cause it to heat excessively, thus shortening its lifespan. I wouldn't have thought that it would cause the supply to malfunction immediately. However, I've been known to be wrong (more frequently than I'd like to admit). I'll see if I can get my hands on some better caps. Maybe it really is that simple. Thanks for the feedback!
        Troy
        • dragon16
          • Nov 2012
          • 5
          I've replaced all but one of the caps with United Chemicon LXY series. For the other one, we only had Illinois Capacitor RZS series in the correct size. The RZS series is low ESR, and intended for use in switching power supplies, per their website here.
          Unfortunately, the same symptom still exists.
          An engineer that I work with suggested that if a switching FET is heating up, it's likely because the gate voltage is too low, and it is operating in linear mode. With this in mind, I checked the Gate-to-Source voltage with a scope. One FET is getting pulses between 9 and 10 volts, while the other is only getting a little less than 3 volts. The datasheet for the switchers shows that they need over 7 volts to get out of linear range. Looks like I have a gate drive circuit to troubleshoot. Anybody have any experience with such things? It's probably a little over my head.
          • jazpa
            • Dec 2012
            • 5
            • usa
            I have a polaroid 3732 model 3700 and i have no power no standby light nothing change the cap and everything but still nothing fuse are good aswell what else could it be keeping me from getting power to make the led come on
            • selldoor
              Slow Learner
              • 7870
              Changed THE cap or all the caps - including any small 50v22uf ones?
              What make series did you use?
              We can sometimes help a lot more if you please post good clear pictures (Well lit but no flash) of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
              Examples of what is needed
              https://www.badcaps.net/forum/attach...7&d=1280167246
              https://www.badcaps.net/forum/attach...6&d=1280167246
              https://www.badcaps.net/forum/attach...4&d=1280167246
              • johnboy1313
                • Nov 2012
                • 1959
                You might want to start a new thread.
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • kitor
                  Dell Latitude 7390 - all power rails up except VCC_GT, no image.
                  by kitor
                  I have Dell 7390, LA-F311P.
                  AFAIK there's no schematics available, but there's one for LA-F312P in this thread. It differs in no Thunderbolt controller (iirc that's for 5290/5390), however rest of the schematics/BV seems to match 1:1.
                  Behavior:
                  Connected barrel plug, no RAM:
                  - power LED turns on + orange light on front
                  - turns off after a second or two
                  Connected barrel plug, with RAM:
                  - power led turns on + while light on front
                  - after a few seconds power led turns off, white light...
                  07-26-2022, 09:53 AM
