Samsung PS50430A1 Crack on the screen
  • bohaboha
    • Nov 2012
    • 1016
    • sweden
    Samsung PS50C430A1W
    here i add the information on the label :E233314H
    850HW-YB06
    code( BN96-13266A)
    and a codbar:HU20BN9613266ABMRZZ9F0778
    hi new here and even novis in electronic and even my English is not the best but i´ll try to explain the best i can.As the title the screen get a smash so the tv have no picture but there is a sound I enclose here a few pictures that might help to help me. the question here is whether it is possible to remove the first glass sheet which it use to be a protection but are not entirely sure because I see that there is 6 ribon connectors on one side and only two for the other side are probably glued to the glass plate is there anyone who knows? when it comes to the main circuit then there is a capasitor that is swollen I thought ask first to know if it is worth the effort before starting something else thank you
  • bohaboha
    • Nov 2012
    • 1016
    • sweden
    Re: Samsung PS50430A1 Crack on the screen
    out of topic why my thread have bleu flagg and all the other new ones havve a red one
    • randtek
      • Oct 2011
      • 280
      • US
      If your panel is cracked on a plasma, you're pretty much out of luck. You will have to replace the panel to get it working again.
      • bohaboha
        • Nov 2012
        • 1016
        • sweden
        thank you for the answer but i wonder if it is not only the protection ho is broken ?
          Does the TV make a loud buzzing sound? If so, the panel is bad.
          • bohaboha
            • Nov 2012
            • 1016
            • sweden
            hello and thank you again there is no strange sounds att start just a kling sound and then like normal sounds and normal moving to other chanels .in the back side on the Tcon there is a green light blinking also there is ho seems to be a bad cap on the power board i´ll replace that one to see if it gives any change
            • Mt.Man
              • 53
              The PDP panel is cracked. Don't was your time replacing other parts. Only thing thats going to bring this TV back to life is to replace the plasma panel, which is not cost effective. Use this TV for parts.
                Whenever the panel is cracked, you will get absolutely no light emission. However the rest of the TV will behave as if nothing has happened.
                • Mike Jenk
                  • Jul 2012
                  • 113
                  The TV is only worth gutting at this point and is worth gutting the parts and possibly helping out someone else in the future with with those parts you pull out of it. I just stripped one of these last month and gave the metal and screen to a local metal guy.
                  • bohaboha
                    • Nov 2012
                    • 1016
                    • sweden
                    tank you it is what i think to do in case it will not work i just give it a try
                      It's terminal... When the plasma screen cracks, it doesn't work any more.
                      • bohaboha
                        • Nov 2012
                        • 1016
                        • sweden
                        hello I woold like to know if these models have a built-in glass plate? because there are two pieces of glass on each other but on closer inspection the one on the top have rubon contact glued on it I was talking about earlier, anyhow i ´ll just change one capacitor and se if it gives anything
                          These plasmas don't; I'm only aware of Panasonic using a toughened glass plate which goes in front of the plasma panel. If either layer breaks, the TV doesn't work any more, and the fault isn't repairable, no matter how many capacitors you replace, it'll never work...
                          • bohaboha
                            • Nov 2012
                            • 1016
                            • sweden
                            thank you for a clear answer the capacitor have to be changed anyhow cause it is the only one ho looks broken this in a case if shall sell it so i have to have it working fine
                            • IamCanadian
                              • Nov 2012
                              • 119
                              Do you have it working yet?
                              • bohaboha
                                • Nov 2012
                                • 1016
                                • sweden
                                Hi I have not had time the last two weeks, but hopes to start the next week
                                  Seriously! Don't bother. It's not repairable. Sorry!
                                  • bohaboha
                                    • Nov 2012
                                    • 1016
                                    • sweden
                                    i did understand that allready from all precious explanations from all of you wonderfull peopole thank you
                                      Sorry to be the bearer of bad news but it's one of the few unrepairable faults. Until someone invents a way to heal the holes in the glass, and re-gas the panel. But I doubt that will happen...
                                      • Chrissygizmo
                                        by Chrissygizmo
                                        02-10-2025, 12:33 AM
                                      • Chrissygizmo
                                        samsung galaxy ao2s very temperamental after screen replaced
                                        by Chrissygizmo
                                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                        Ive eventually managed to get it on and working but it's very temperamental...
                                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                        05-26-2024, 12:05 AM
                                      • JunkmanJimbo
                                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                        by JunkmanJimbo
                                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                        Please help. Thanks in advance!
                                        08-12-2025, 11:45 AM
                                      • Kiberge
                                        Samsung LH82QENELGC/EN Help needed - Static line on screen
                                        by Kiberge
                                        HI guys!
                                        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                        04-22-2024, 11:28 AM
                                      • Ryan.man
                                        by Ryan.man
                                        02-04-2025, 12:23 PM
