Lg LCD 47in
  • Rcgui
    • Nov 2012
    • 7
    • United states
    Lg LCD 47in
    Hi I'm new to this site but it seems like the place to go for this issue.
    Anyway, I recently acquired a LCD tv that stays on for an hour then shuts off. I haven't got much time to play around with it. I was thinking it could be the power supply board, but I'm not a hundred percent. Anbody have any thoughts? I can post pics if wanted or go more in depth, I just haven't had it long.
    Rcgui
  • gilly1984
    • Jun 2012
    • 751
    Re: Lg LCD 47in
    You might want to stick this in the tv section pal, you will get some help there.
    Make sure you search the forum first too.
    And check the terms and stuff.
    It would help if you have a multimeter and a decent cam for pics.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Lg LCD 47in
      Moved from FAQ.
      Please (to everybody not a Mod or higher), if you notice any more out of place threads, report them. We can only do what we either happen to notice (which is far less) or more importantly, what we are told about. Look how long it took me to stumble upon this...
      sigpic
      (Insert witty quote here)
      • Hondaman
        Cold temperature battery damage?
        by Hondaman
        A couple of evenings ago, my cell phone spent 6-8 hours on the floor of my car, which was parked on the driveway. Probably at or below 0 Celsius. When I took the phone inside, it was turned off, and the battery was at 0 percent (Galaxy S10 Plus). I charged it (wirelessly) without letting it warm up (yes, I know that was probably a mistake -- I probably should have put the phone onto an electric blanket I have).
        Now, when the battery reaches something like 72 percent or 75 percent, it charges normally. Below that point, it takes 90 minutes to add 10 percent to the phone's battery charge....
        01-05-2025, 05:22 AM
      • dicky96
        Need LAN connection over several hundred meters - how to do this?
        by dicky96
        Hi guys
        Here is a project I have been working on. I am supplying a company who have a license from the government to re-open the open air markets which have been closed due to COVID-19
        They have to fulfill certain restrictions to open the markets, we are currently three weeks into an eight week trial.
        The main requirements are:
        1. The temperature of every person visiting the market is taken.
        2. There is a capacity limit of how many people can be in the market at a given time, and it must be observed.
        3. Everyone must wear a mask (Actually...
        11-05-2020, 12:15 PM
      • bart64
        ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
        by bart64
        After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
        10-18-2025, 05:51 AM
      • EvazX
        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
        by EvazX
        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
        However, after some time, the replacement motherboard...
        08-25-2025, 06:09 PM
      • ferah831208
        help with bios decompose for Asus s5506ma
        by ferah831208
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
        08-24-2025, 05:35 PM
