Cold temperature battery damage?
  • Hondaman
    • Sep 2008
    • 1087
    A couple of evenings ago, my cell phone spent 6-8 hours on the floor of my car, which was parked on the driveway. Probably at or below 0 Celsius. When I took the phone inside, it was turned off, and the battery was at 0 percent (Galaxy S10 Plus). I charged it (wirelessly) without letting it warm up (yes, I know that was probably a mistake -- I probably should have put the phone onto an electric blanket I have).
    Now, when the battery reaches something like 72 percent or 75 percent, it charges normally. Below that point, it takes 90 minutes to add 10 percent to the phone's battery charge. EDIT: This is true for both wired AND wireless charging. So if my phone is very low, like below 20 percent, it's going to take a LONG time to charge it up. This is true for both wired AND wireless charging.
    I find kits on Amazon and eBay to remove the glue, remove the back from the phone, and replace the battery. I think have the skills to do this. But is this a problem with the charging circuit or the battery? If the charging circuit is defective, a new battery will not help.
    (Sure, I'd love to get the Samsung S23FE, brand new, NOT locked to any US cell phone company, for about $490, but I would also like to save my money......)
  • mon2
    • 14577
    To me, it is the battery. There are numerous vides on YT on how to replace the battery. You can also shop around with your local phone shops for the same service. It is a very competitive market and many will offer the replacement at close to the battery price since they are most likely doing the same, probably daily.
    https://www.youtube.com/watch?v=M6ssGO072RM
    Suggest to buy from Amazon since you have the right to return the purchase for any reason within the return period.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
      Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
      I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
      I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
      05-26-2024, 10:44 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
