Panasonic PT-47WX42 Convergence Issues
    Re: Panasonic PT-47WX42 Convergence Issues
    Do you have access to a scope? You'd need to check if the waveforms going into the driver ICs are bad and if the waveforms coming out are good or bad.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I do have an old 1 channel AC scope (1965 heathkit 1012). The issue is that getting to the chips while the board is installed is a pita (its in the back of the cabinet, right by the blue CRT neck card)). I may give it a try later.
      sigpic
      (Insert witty quote here)
      • Mr Bill
        • Nov 2011
        • 648
        The only thing that i can suggest is check and make sure all the connectors are correctly placed. When i repaired the projection tv in may i goofed and didn't label any of the connectors. That was a big mistake on my part. When we turned the tv on for the first time the colors were WAY off and you couldn't do any convergence adjustments (manual or auto). It took a few minutes of head scratching but i did finally figure it out. I had 2 connectors that needed switched. I do also remember the remote didn't work either until i switched the 2 above connectors.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I'm pretty sure I got the 3 tube control cables right. I'll double check just to be sure.
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I finally was able to check... the cables were in the right order (I traced them to the PSU/HV board and used the PCB marks to verify).
            I remeasured all the resistors and checked all of my soldering... Came up with nothing.
            Anybody else have any suggestions? (I hope I get replies, threads get buried within hours in this subforum)
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Looked for other advice online, I found nothing other than "buy the kit" or "buy the service manual". No actual help.
              I'm really thinking it's fucked... the only other possibility that comes to mind is that my chips are bad. They looked slightly different from the old ones... and I did get them on ebay... fakes?
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                After looking around online, I see people mentioning failed jobs due to fake parts.
                Here's the link I bought from:
                http://www.ebay.com/itm/270750562673...84.m1439.l2649
                Whose pic matches what I bought:
                The ones that came out looked more like this IIRC:
                Fakes?
                I'm suspecting I got screwed... if they are indeed fakes, then its a good thing I have yet to give feedback.
                sigpic
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Fake IC?
                  Real IC?
                  Fakes?
                  The 'real' ones seem to have different 'K's and different '-' than the 'fake' one.
                  The only way we might be able to tell is the back, the heatsink pad. Copycat parts sometimes look ok, but (just like the fake caps) there is almost always one little detail they missed! (Ok, maybe two, counting the incorrect font!)
                  Muh-soggy-knee
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Yeah, I think I got %^&*ed by fakes this time. I'll order some known legit ones and try again.
                    edit- Anybody know where I can get reliable parts from? Newark has NTE ones but they want $15 a pop plus shipping (I had a x% coupon from them, but I may have used it).
                    edit- found the 15% off code, buying them there.
                    sigpic
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      When you get this working you should carefully cut open the old one with a dremel, and compare that to the insides of the 'fake' one! Would be interesting to see the difference xD
                      Muh-soggy-knee
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Unless I have to mail them back for refund... oh wait, by the time I get them, I bet my 14 days will be up. I may have to grab my dremel and once again pull a ratdude...
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          got the new chips, no change.
                          I'm running out of ideas. I wish I had the schematic but The only places that have it wanna charge $$ for it.
                          Anybody have any other suggestions?
                          sigpic
                            Is this the SM?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Is this the SM?
                              Nope, thats the user's manual. Already have that.
                              sigpic
                                I dunno then -- but have you tried scoping the input to those ICs to see if it's the same as the output?
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  No... because I can't really get to where I need to go. It's very cramped and a royal pain to try to look at a scope and get my lead on the pin at the same time. It was hell enough trying to check my supply voltages, which were suppossed to be + 18, -18, I got +17.5, -20.1 (the chips is rated up to +38. -38).
                                  sigpic
                                    If I have that problem, I solder a lead to the relevant part of the board and scope it that way. I suppose the chassis design means it's very hard to get the boards out, though...
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      nah, its just that the chips are at the back of the cabinet.
                                      I did scope them... nothing. nothing AC, that is. Minus the same amount of ripple I saw on the supply voltages.
                                      Stupid money pit... #$%^!
                                      sigpic
                                        So I thought you had deflection, but it was messed up?
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          could you rephrase that?
                                          sigpic
                                          • HKS00
                                            Panasonic CF-20 Track pad issues
                                            by HKS00
                                            Hello Everyone,
                                            My name is Haris and, I am new to the forum. I would appreciate any help I can get.
                                            Little back story on me and the issues that we are dealing with...
                                            I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
                                            03-08-2023, 10:34 AM
                                          • newgen2005
                                            Panasonic DMR-ES30V power issues
                                            by newgen2005
                                            I picked up a Panasonic DMR-ES30V (UK). When I first plugged in there was nothing, appeared completely dead, I then turned it on and off a couple of times at the mains supply and it came on. It accepts a cassette but then spits it out straight away, the DVD drive functions sometimes but then the unit turns off with nothing on the display. I took the back off and noticed the fan does not spin. The display for the DVD side does seem a little dim when it is working.
                                            I have looked on google and people say it is most likely a capacitor/s.
                                            Just looking for some advice on which...
                                            09-26-2024, 03:49 AM
                                          • gre0013
                                            Panasonic TC-59R62 Overscan issues. How to adjust?
                                            by gre0013
                                            Hello. I need help opening the service menu on a Panasonic TC-59R62
                                            Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
                                            Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
                                            07-26-2024, 10:14 PM
                                            NETGEAR and issues with it forgetting password or just going off line fairly new
                                            by sam_sam_sam
                                            I have for many years have used NETGEAR routers and most of the time I get about 2 to 4 years of service before I have issues with it but this one is a pain in the a** to say the least
                                            First of all it goes offline for no reason at all
                                            Or it has an error message that says no internet connection
                                            The other issue is that sometimes it asks for the password also for reasons that I can think of
                                            Power cycling it helps but a week or maybe longer then you have some kind of issue like website loading very slow or can not access the printer or whatever it decides...
                                            03-18-2023, 07:36 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
