Sanyo Turns off when sound turned up
  • shorteddiode
    • 221
    Sanyo Model DP47460 wors great and will play non-stop if you do not turn the sound up past 38. I have replace pretty much all the caps on the power and main board. (The caps with the red tops are the new ones) Does not matter which input you use the magic number is still 38. The tv will turn back on but if you don't switch inputs to a no signal and lower the volume it will turn back off. After about three shut downs the set has to be unpluged for awhile before it willl turn back on. I am stumped I did check the resistors on the power supply too, no problem found.
    Power board # 1LG4B10Y04800
    MainBoard # 1AA4B10N24700
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sanyo Turns off when sound turned up
    Since it looks like you can reproduce this quite easily, I suggest taking before and after voltage measurements of all your connectors and voltage regulators on the main board.
    For example, set volume to 1, record all your voltage measurements. Do the same for 10, 20, 30, and 37.
    See if there are any significant changes between those 5 settings. You may spot something abnormal?
    --- begin sig file ---
    --- end sig file ---
      My bet would be the green caps - C630H1 and one I can't see, under the heatsink. I have seen this problem on Vestel TVs (different PSU but similar topology), and it is usually those two caps.
      Oh, and if the sound is quiet, does it still cut out at 38?
      • f67bird
        Technician
        • Apr 2007
        • 57
        It's most likely IC1670. This is an 8 pin surface mount ic. It has a ground pad underneath the body of the ic that is also soldered to the board.
        It drops 24 volts down to 13 volts to run the audio output circuit.
        It's located on the top side of the board about an inch to the right from the speaker connector. The sanyo part number is QXXGA0500165P.
        Learner
        • f67bird
          Technician
          • Apr 2007
          • 57
          I took your photo of the main board and drew a black outline around the ic.
          The ground pad below the ic makes it tough to remove from the board without
          hot air.
          Learner
          • shorteddiode
            • 221
            Thanks guys, I'll try the voltage checks. I have hot air, (My wife tells me I am full of it)
            So I'll order the chip and change it out. I'll let eveyone know the results
            • shorteddiode
              • 221
              Well I looked to buy the chip but can't find a supplier. Anyone have a lead on Sanyo parts?
              • kevinm34232
                • May 2012
                • 1884
                There may also be an IC001 audio amp that could be the problem.. You'll have to check the 13v line and see if it drops off...
                  I remember that now when I was helping you on that Sanyo DP42840 where I posted my notes as shown in post 4.
                  • kevinm34232
                    • May 2012
                    • 1884
                    Yep. Mine would not turn on at all and 13v line was low due to shorted audio amp IC.
                    • f67bird
                      Technician
                      • Apr 2007
                      • 57
                      I think you will have to get it from Sanyo themselves.
                      I have a number to try: Sanyo parts phone #: 18008775036 ext1485
                      The number on the part is LV5806MX-TLM-H but you will have to use the Sanyo part #QXXGA0500165P
                      Sanyo is the original manufacturer of the part. It's a step-down switching regulator...pdf here
                      Let us know what they say.
                      Learner
                      • BoJaXz
                        • May 2013
                        • 19
                        I have the same tv, except that when i turn mine on, it just shows the sanyo start-up screen, then shuts off again. i'm new to the whole "fixing tvs" scene, but i'm learning quickly. any thoughts on what the problem would be? i'm trying to do it myself to save $100 on what might or might not be the problem.
                        • Clydeuk
                          • Jan 2012
                          • 193
                          Bit messy but if you can isolate the supply for the audio stage, try feeding it off a separate source, 12v will probably be fine. If it goes past the point where shut off occurs you probably have a fault in the power supply. It could be that there is something amiss with the 24v rail since the supply is derived from there, or some protection circuit is malfunctioning.
                          • BoJaXz
                            • May 2013
                            • 19
                            I did notice that with the ac plugged in, tv off, the 24v rail had 24v on a couple of the negative terminals. I wish I could find a diagram of the main board and ps board that tells what goes to what.
                            • BoJaXz
                              • May 2013
                              • 19
                              Does anyone have a service manual for this model?
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Sorry I'm late. Try this.
                                • BoJaXz
                                  • May 2013
                                  • 19
                                  Thank you!!
                                  • BoJaXz
                                    • May 2013
                                    • 19
                                    so i got another chip for the mainboard. it isn't exactly the same one. the original has a ground pad under it, i'm not sure what the significance is of it. but i replaced it with one that doesn't have a ground pad for some reason. and now i get even lower voltage coming out of it from 2.8v to 1.6v
                                    • BoJaXz
                                      • May 2013
                                      • 19
                                      It's a lv58063mx the original chip only says v5806. Doesn't give much to go off.
                                      • nubleet
                                        • Aug 2013
                                        • 16
                                        This info is golden! Has anyone had any luck with this repair? I received a DP55360a with the same issue as BoJaXz (Displays splash screen the turns off). The unit has the same N8TE main board. I have reflowed the BGA on the board then i found this thread.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • hugocarmo
                                          Sanyo VHR-D4710G VCR no sound.
                                          by hugocarmo
                                          Hi again guys.
                                          Today I have a problem with this Sanyo VCR.
                                          I bought it online, It worked sometimes.
                                          I recap the Power supply and it started working fine.
                                          Image is perfect and all digital effects too.
                                          All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                                          I have no sound on playback, on tuner, or aux in.
                                          On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                                          On one of the sound processing...
                                          01-23-2024, 12:58 PM
                                        • Zilicon
                                          AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                                          by Zilicon
                                          Hearty greetings to everyone, trust you all are doing excellently well.
                                          Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                                          The power stables in very rare case. Once it was stabled, everything works fine.
                                          Once the power switched is pressed, 5V and 3V were present.
                                          The things i have done:
                                          1. I have check for shorts on the board, but nothing. The board is short free
                                          2. Not a power switch problem, it behaves the same without the switch ...
                                          06-10-2024, 05:05 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
