Jvc jlc32bc3000
  • Nam3o
    • 44
    #61
    Re: Jvc jlc32bc3000
    will not turn on at all. the power led is on but that's no change.
      Re: Jvc jlc32bc3000
      You say it stopped turning on reliably -- does this mean it would turn on once in a while, but not always? Did it get slowly worse over time?
      • Nam3o
        • 44
        #63
        Re: Jvc jlc32bc3000
        correct.
          Re: Jvc jlc32bc3000
          Originally posted by Nam3o
          correct.
          OK, I am going to bed now (lecture at 9am) but I will give you this video to go through:
          https://www.youtube.com/watch?v=cNFzBJELFoU
          Please test all the regulators like norcal outlines. It's a different chassis, but Vizio (and Vizio parts) are well known for regulator problems.
          • Nam3o
            • 44
            #65
            Re: Jvc jlc32bc3000
            well I may have killed it good now. I was testing voltage at the regulators and may have shorted out something. now the front LED IS OFF and when I plug in the power the speakers pop. also the F3A fuse is blown.
              Re: Jvc jlc32bc3000
              You may be lucky; check both ends of the F3A fuse to ground, and if they're greater than about 10 ohms, replace the fuse. If your probe just slipped, it likely only blew the fuse. (You can solder a new fuse across it, or temporarily use a car fuse with wires soldered to it.)
              • Nam3o
                • 44
                #67
                Re: Jvc jlc32bc3000
                I replaced the PSU with one from Shop Jimmy. still no progress. main board issue?
                • Nam3o
                  • 44
                  #68
                  Re: Jvc jlc32bc3000
                  I might just buy this but would like to fix the old one
                  http://www.shopjimmy.com/tvs/interna...lc32bc3000.htm
                    Re: Jvc jlc32bc3000
                    The PSU was probably fine (it is nearly impossible to break a TV PSU by slipping the probe -- the power supplies are short circuit protected); you should test the old one.
                    $75 is a lot to spend on a 32".
                    • Nam3o
                      • 44
                      #70
                      Re: Jvc jlc32bc3000
                      I did get it for free
                      • Nam3o
                        • 44
                        #71
                        Re: Jvc jlc32bc3000
                        how do I troubleshoot the main board?
                          Re: Jvc jlc32bc3000
                          Can you post a picture of it?
                          • Nam3o
                            • 44
                            #73
                            Re: Jvc jlc32bc3000
                            let me know what else you need
                              Re: Jvc jlc32bc3000
                              Test all the voltage regulators as indicated in this thread:
                              https://www.badcaps.net/forum/showthread.php?t=22231
                              • Nam3o
                                • 44
                                #75
                                Re: Jvc jlc32bc3000
                                this regulator has .1mV on all the pins
                                  Re: Jvc jlc32bc3000
                                  That is fine, no input == no output
                                  • sephora99
                                    • Jun 2013
                                    Re: Jvc jlc32bc3000
                                    I know this is an old thread, but I was wondering what became of this. Did you ever fix the main board issue? Did you replace the main board? Did you ever get this set working again, or is it headed for the trash?
                                    I picked up one of these sets with the same issues all the way down to the last step. I found I could turn mine off and back on with the power button but if I allowed it to put itself to sleep then it would not come back. In which case I have to let it sit for an hour before it will come back on.
                                    Please tell me you found a solution. I would really like to know if you replaced the mainboard in this. Thanks.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      Re: Jvc jlc32bc3000
                                      Bumping this up
                                      I just got one of these JVC/Vizio made panels. I have 5v but no 12v. Was this determined to be a mainboard issue?
                                      I see there are EEPROM available and one of the causes could be tv will no power on. Mine sits with the red LED on and no change with remote or hitting the power button.
                                        Re: Jvc jlc32bc3000
                                        Check PS ON signal from main board. If low/missing, indicates it is a main board issue.
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
                                        • jose6326
                                          Samsung s32d850t powers off
                                          by jose6326
                                          Powers on as normal shows an image then powers off after 10 seconds
                                          I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                          No blown caps
                                          I searched for this model but nothing comes up...
                                          11-29-2024, 11:21 PM
                                        • Topcat
                                          Dell XPS 8950 Power Issue
                                          by Topcat
                                          A few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
                                          Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
                                          Basic test:
                                          Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else....
                                          01-02-2024, 05:51 PM
                                        • Rekoo1997
                                          DELL Precision 3520 powers on automatically
                                          by Rekoo1997
                                          Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                                          Issue: The laptop powers on automatically after being shut down.
                                          Actions Taken by Technician:
                                          BIOS reflashed
                                          Intel ME region cleared
                                          Result: Issue still persists
                                          Additional Observations:
                                          Power button reads 3.3V (normal)
                                          The problem occurs both when running on battery and when connected to AC adapter...
                                          08-07-2025, 08:48 AM
                                        • simwalsh
                                          Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                          by simwalsh
                                          I am new to this forum and have searched for some answers with problems similar to mine.
                                          Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                          It sounds like a power supply issue?
                                          I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                          12-04-2023, 04:03 AM
