Dell XPS 8950 Power Issue
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    A few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
    Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
    Basic test:
    Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else. Power button is unresponsive (yes I checked to make sure it was good, it is). Only way to replicate this is to remove the power cord and reinsert it.
    Troubleshooting attempt:
    1) Removed CMOS battery & cleared NVRAM. Nothing changed.
    2) Removing RAM & GPU (connected display to onboard displayport), symptoms do not change.
    3) If I unplug the 2x +12v CPU power connectors by the processor, the unit powers up. power LED on the front blinks 2x white and then 4x amber codes and then eventually powers back down; yet continually & indefinitely blinks the codes. All this time, power button is unresponsive to anything; momentary presses or Press & hold.
    4) Now here's where it gets strange. If I probe all the power connectors WITH THE SYSTEM POWERED DOWN (power connectors plugged into the board AND unplugged as well), there is what I believe to be correct voltages on all pins; +12v & 3.3v. The 12v rails read 12.26 regardless of whether connected or not. The only position that does not have power is the +12v on the PCIe GPU connector. If I trigger the PS_ON leg (blue wire on main 10-pin plug) to GND, the PSU starts (relay clicks, fans come on, and 'power_good' LED on the rear illuminates. Voltages don't change excpt the PCIe connector now has +12v present. Bizarre....
    What a disgusting system this is, especially for it to be so new.... I doubt the owner will want to fix it anyway....but I'd like to figure this out....and I do believe it to be the motherboard....but input is appreciated!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • 31151
    attempting to boot several times is what intel systems do if the bios checksum is bad - or the bios just cant be read/seen
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
    • popzeggey
      Dell Precision 7520 power issue
      by popzeggey
      Hello, I have the similar problem. My Dell Precision 7520 doesn't turn on with only battery. Below are the various scenarios and its symptoms
      1. With only battery, the laptop turns on but no display and shuts down after few seconds
      2. With battery and charger plugged in, the battery light comes on. But pressing the power button does nothing and laptop refuses to turn on. However, the battery led light blinks every 17seconds from when the charger is plugged in with or without battery. So whether the battery is inserted or not, the battery led light will turn when charger...
      06-07-2024, 09:23 PM
    • lowpost99@gmail.com
      Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
      by lowpost99@gmail.com
      I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
      09-03-2024, 02:57 PM
    • zlr8r
      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
      by zlr8r
      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
      Ill try and give as much info as I can.
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      When I received this , it would only flicker on the KB backlight for a second, then off and on.
      Then it started getting weirder!
      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
      12-12-2023, 09:31 PM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
