Jvc jlc32bc3000
  • Nam3o
    • Dec 2010
    • 44
    Jvc jlc32bc3000
    This TV powers up normally if it has been unplugged for an hour or so. The TV will work for as long as you keep it on. After you turn it off it will not come back on. I have replaced the caps on the power board to no effect.
    Re: Jvc jlc32bc3000
    Can you show us some pictures of the power supply? Do you have a digital multimeter?
    • Nam3o
      • Dec 2010
      • 44
      Re: Jvc jlc32bc3000
      I used photo bucket because the pics are big.
      here is the power supply
      http://i1199.photobucket.com/albums/...0/IMG_1935.jpg
      Here is a better look at the connector
      http://i1199.photobucket.com/albums/...0/IMG_1936.jpg
      And here is the main board
      http://i1199.photobucket.com/albums/...0/IMG_1937.jpg
      • Nam3o
        • Dec 2010
        • 44
        Re: Jvc jlc32bc3000
        I do have a multimeter and if you tell me what you need I would be happy to test it. the TV has been unplugged sense yesterday so it might even come on.
          Re: Jvc jlc32bc3000
          What were the original caps -- were they similar to the brown colour of the main big cap? I think the caps you have used as replacements are possibly worse than the originals.
          And wow, it looks like it might be a re-badged Vizio TV, given the AmTRAN main board.
          • gilly1984
            • Jun 2012
            • 751
            Re: Jvc jlc32bc3000
            New caps look like Elite.
            Do NOT touch heatsinks when testing for voltages as they may be LIVE!
              Re: Jvc jlc32bc3000
              Yes, and Elite capacitors are very far from "Elite".
              • gilly1984
                • Jun 2012
                • 751
                Re: Jvc jlc32bc3000
                Yep, forget which thing i was looking at that had them.
                  Re: Jvc jlc32bc3000
                  Interesting... http://www.prnewswire.com/news-relea...125181189.html
                  • gilly1984
                    • Jun 2012
                    • 751
                    Re: Jvc jlc32bc3000
                    Is sam young a make of caps?
                    http://www.shopjimmy.com/vizio-0500-...t-inverter.htm
                    Hover over to enlarge the caps.
                      Re: Jvc jlc32bc3000
                      Yeah, but most of them are Chemicon, which are good. Samyoung are iffy, but usually OK if not abused.
                      • gilly1984
                        • Jun 2012
                        • 751
                        Re: Jvc jlc32bc3000
                        So, were they the originals, or does shopjimmy upgrade them before selling on?
                          Re: Jvc jlc32bc3000
                          They are most likely originals.
                          • gilly1984
                            • Jun 2012
                            • 751
                            Re: Jvc jlc32bc3000
                            Originally posted by tom66
                            Last message on this guys thread, unless i can help more.
                            But i always thought JVC was crap? There stuff seems really plastic(y) and cheap. Well, at least there pmpo all in one hifi's are anyway.
                              Re: Jvc jlc32bc3000
                              No, it's pretty decent -- as long as it's not the rebadged stuff, which in the UK is Vestel and UMC. But they still make 40", 46" and 52" LCD/LED sets, entirely by themselves, and they have excellent caps in them and good build quality. Also their CRTs are well made, and were previously UK made.
                              • gilly1984
                                • Jun 2012
                                • 751
                                Re: Jvc jlc32bc3000
                                Decent brands should keep all there own stuff inside, like the philips tv i am fixing. Everything is philips inside. Even most ic chips have philips on them. It is 7-8 years old though.
                                  Re: Jvc jlc32bc3000
                                  Yeah, they should, but there's more money re-badging cheap tat. Thing is, this stuff will die a few years down the line, customers will be pissed, and never buy JVC/Toshiba/Sharp again (all rebadge some LCD models.)
                                  I bet the other ICs have NXP on them, it was founded by Philips to take over their semiconductor division.
                                  • Nam3o
                                    • Dec 2010
                                    • 44
                                    Re: Jvc jlc32bc3000
                                    alright thank you all it was good info. but the power dose not seem to be the problem. is it possible that the signaling circuit for power on/off is stuck in some way? if so where and how do I identify the offending part. also this is not the first time I have worked on an LCD this one just behaves strangely. and as for the caps I used (Lelon) I got the cheapest ones I can find, if I have to do it again later I will definitely ask here first.
                                    • gilly1984
                                      • Jun 2012
                                      • 751
                                      Re: Jvc jlc32bc3000
                                      Never use the cheapest you can find. After a while on this forum i have come to the conclusion that if it doesn't say "Rubycon" "Nichicon" United chemicon" or "panasonic" on it then it could probably do with replacing with one of them brands.
                                      Are the caps you used even low esr? The caps you replaced have probably aged, with them aging have most likely gone too high in esr and caused your problem, then you have replaced them with caps that have crap esr anyway so you are left with the same problem?
                                        Re: Jvc jlc32bc3000
                                        I would say the Chemicon and Samyoung were probably OK to start with. Cheap caps will be a problem in a year's time. PSU will work even with Radioshack caps, just not for long.
                                        OP -- please test the Remote ON/OFF pin.
                                        You should find that the ON/OFF pin changes voltage when you press the power button.
                                        Check if it does this when in the faulty condition too.
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
                                        • jose6326
                                          Samsung s32d850t powers off
                                          by jose6326
                                          Powers on as normal shows an image then powers off after 10 seconds
                                          I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                          No blown caps
                                          I searched for this model but nothing comes up...
                                          11-29-2024, 11:21 PM
                                        • Topcat
                                          Dell XPS 8950 Power Issue
                                          by Topcat
                                          A few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
                                          Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
                                          Basic test:
                                          Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else....
                                          01-02-2024, 05:51 PM
                                        • Rekoo1997
                                          DELL Precision 3520 powers on automatically
                                          by Rekoo1997
                                          Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                                          Issue: The laptop powers on automatically after being shut down.
                                          Actions Taken by Technician:
                                          BIOS reflashed
                                          Intel ME region cleared
                                          Result: Issue still persists
                                          Additional Observations:
                                          Power button reads 3.3V (normal)
                                          The problem occurs both when running on battery and when connected to AC adapter...
                                          08-07-2025, 08:48 AM
                                        • simwalsh
                                          Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                          by simwalsh
                                          I am new to this forum and have searched for some answers with problems similar to mine.
                                          Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                          It sounds like a power supply issue?
                                          I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                          12-04-2023, 04:03 AM
