Trying to determine bad panel or t-con on Proscan TV
  • ranergeo
    • Oct 2012
    • 90
    • US
    Heya! I've acquired a Proscan 42LED55SA tv that originally would turn off after about 2 minutes or less. Changing out the caps on the PCB solved that problem, but I was left with sound and a screen full of vertical red/green/grey-black lines (I've attached a picture attempting to show this, but still difficult to pic up with my camera!). I checked all the regulators on the t-con and the main board, and they all check out fine.
    Since I saw lines on the screen, I decided to get another t-con supposedly out of a working set with a damaged screen, and I get 1/2 screen with a negative like image, and 1/2 screen full of grey and white banding. I've checked the ribbon connectors for proper seating with the picture staying the same each time.
    The only "odd" thing I can find on any board is that one set of output voltages from my PCB to the Main is a 16VDC output putting out 17.2VDC (the 3.3, 5, and 24V outputs are all o.k.). Would this cause a problem, and how would I find the culprit on the board? If this wouldn't affect anything, could anyone offer a suggestion as to whether the problem is the t-con or panel (or something I've not thought of yet!!)? Thanks!!
    Re: Trying to determine bad panel or t-con on Proscan TV
    What is the voltage going to the T-con? Some T-cons use that voltage directly to drive the screen, if it is too high, it can cause problems. Personally I would suspect the T-con as it is rare for the whole panel to fail at once. It is possible, but rare.
    • ranergeo
      • Oct 2012
      • 90
      • US
      Thanks for the reply tom!
      I have 11.82VDC at the fuse on the t-con, and 3.3V at the regulator. I had a hard time thinking it was the panel either, but with a supposedly new t-con, I figured it would clear up, unless it also was bad, or the wrong one for the tv (I got the same p/n, but some of the other board info was diffrent )
      • MisterD
        • Oct 2012
        • 668
        I saw a video on youtube where someone used cold spray/component cooler and sprayed it at the front edge of a lcd screen under the plastic bezel so it would get into the screen and if it corrected the lines in that area the screen was bad, I have never tried this and not sure about this method, but you may want to check into it or see if anyone has any advice about it.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          Today, 02:09 AM
