olevia lcd tv has no sound until the tv warms up
  • azdave35
    • Oct 2012
    • 12
    • usa
    Re: olevia lcd tv has no sound until the tv warms up
    yes..i have cable tv hooked up to the uhf port...but when i hook an antenna to the dtv port there is no option to scan for channels
    • azdave35
      • Oct 2012
      • 12
      • usa
      i have the cable tv hooked up to the uhf port....and the antenna hooked to the dtv port
      • senz_90
        • Aug 2013
        • 328
        • Indonesia
        Sorry for digging this thread and this thread looks old.
        My friend ask me if I could help him to repair his LCD TV because he know I am an electronic hobbyist, but I don't have any experience, so I would like ask for help. I don't want to make a new thread because my friend just said the TV make and it was Olevia likes this thread and he don't describe the model, nobody would see my new thread if no model number.
        He said that someday his son playing the remote and suddenly the tv didn't have a sound and no colour (just black and white). everything fine, just the colour and no sound. From this I think the problem could be fix by factory reset but I am afraid will makes it worse.
        Any ideas? how to enter this TV factory reset and try to not affecting others setting?
        "There is no shortcut to be successful. No pain, no gain."
        Best Regards
        Rudi
        Thank You
        • selldoor
          Slow Learner
          • 7870
          I dont follow this - you should have started your own thread- we still dont know the model. Are you working on it or just relaying the information to your friend?
          • senz_90
            • Aug 2013
            • 328
            • Indonesia
            I am not working on it for now, he just give me information and ask me If I can help him. I want to know the logical culprit for this problem because you all profesional technician maybe ever face this problem before . is this because factory setting has been modified or is this related to hardware failure ?
            If this because factory setting, this tv would be fixed and I could makes some effort to find the answer. If the problem related to hardware, maybe I am not capable to do this job because from I learn from reading book and site about colour and sound problem that is related to mainboard or t-con (colour/line) problem? any help would be very appreciated and thank you
            Best Regards
            Rudi
            Thank You
            • selldoor
              Slow Learner
              • 7870
              #26
              Ok - so there will be a delay between each suggestion and the reply.
              Has he tried the obvious things.
              Is the aerial plugged in.
              Tried other inputs dvd - pc
              Checked to see if the mute button is stuck on the remote.
              Checked the volume down button is not stuck on the remote.
              Removed the battery from the remote then tried it again.
              Tried the same with the controls on the tv.
              Tried adjusting colour contrast brightness and sound on ordinary menu.
              Switching the set off and unplugging for an hour
              Pressing the on off button while set is unplugged.
              ASK him what the model number is.
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                a factory reset will probably sort this out if the son was just messing with the remote control but as selldoor sugests the model number will help us to get the right reset procediure.
                • senz_90
                  • Aug 2013
                  • 328
                  • Indonesia
                  #28
                  Ok. so you are give a clues that something maybe button stuck on remote control, or this is possible to fixed by factory reset, or the others like selldoor suggest.
                  Yes vinceroger69, from my friend explain I have think so it looks like the menu has been changed by his son or the remote button has been destroyed by his son.
                  I haven't go to his house yet to check maybe the remote defective or wrong insertion cable or menu setup changed, but I'll try to get a model number and post a new thread.
                  thanks both of you.
                  Best Regards
                  Rudi
                  Thank You
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Do you have an antenna connected??
                    • senz_90
                      • Aug 2013
                      • 328
                      • Indonesia
                      #30
                      Of course. I said I get the pictures, but no colour, just black and white likes 19xx years old TV
                      Best Regards
                      Rudi
                      Thank You
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • acedogblast
                        Marantz SR5012 popping and other sound issues
                        by acedogblast
                        Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
                        These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
                        I have disassembled the unit and was able to take out the...
                        02-15-2023, 01:40 PM
                      • Christos Tsiligiannis
                        Marian Trace Alpha sound card repair help
                        by Christos Tsiligiannis
                        Hello to the forum.
                        My name is Christos, I am new to the forum here and i am posting from Greece.
                        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                        So i tried asking for a schematic from the company and they would not give me one. Instead they...
                        11-18-2024, 05:26 AM
                      • hopeng
                        Dell AIO 7440 having "popping" sound after motherboard change
                        by hopeng
                        Hi, does anyone know what could be the reason for 'popping' sound during windows start (while window icon showing)? I just replaced a broken motherboard and the sound start happening.
                        Windows starts ok. No noise afterword. But the start up popping sound is scary to me. Not sure if it's safe to use my PC. I've attached the video of the internal of the PC during start up and the sound. thanks....
                        11-12-2020, 05:57 AM
