What would be the best low ESR capacitors to use in an LCD TV PSU? What would I be looking for in the datasheet as in ESR, impedance,frequency? Or can someone recommend some tried and tested reliable ones that I can just install, without having to worry about all the technical stuff?
Low ESR PSU Caps advice
HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Tags: None -
Re: Low ESR PSU Caps advice
I myself use PANASONIC FM series from Digikey, you can also use FR series. Just match the value, voltage, dimension to the original. Use them for many, many, many years in lots of products (http://s807.photobucket.com/albums/yy352/budm/)Attached Filesif you find these attachements useful please consider making a small donation to the site
http://www.badcaps.net/forum/showthread.php?t=24809 -
Rubycon ZL_, Nichicon HD, and Chemi-con KZE can also be good options if you can't find a panny in a particular size.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Thanks for the advice fellas but these are going to be used for the 2 main caps on a SMPS,I should have mentioned that before, is there a particular ohm rating I should be looking for,like some of them are 1.3 ohms,1.8 ohms ect...I want these to last a fair while.HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
Try to get something with low impedance, as close as or below 1 ohm, but don't sacrifice lifetime rating (hours @ 105c) for lower ohms.
The impedance is not that important for capacitors running at high voltage, in the mains section.Comment
Thanks mate,you've answered my question spot on.HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
