Low ESR PSU Caps advice
+ More Options
Posts
  • redrooster
    • May 2011
    • 114
    What would be the best low ESR capacitors to use in an LCD TV PSU? What would I be looking for in the datasheet as in ESR, impedance,frequency? Or can someone recommend some tried and tested reliable ones that I can just install, without having to worry about all the technical stuff?
    HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
    Re: Low ESR PSU Caps advice
    I myself use PANASONIC FM series from Digikey, you can also use FR series. Just match the value, voltage, dimension to the original. Use them for many, many, many years in lots of products (http://s807.photobucket.com/albums/yy352/budm/)
    • c_hegge
      • Sep 2009
      • 5219
      Rubycon ZL_, Nichicon HD, and Chemi-con KZE can also be good options if you can't find a panny in a particular size.
      • redrooster
        • May 2011
        • 114
        Thanks for the advice fellas but these are going to be used for the 2 main caps on a SMPS,I should have mentioned that before, is there a particular ohm rating I should be looking for,like some of them are 1.3 ohms,1.8 ohms ect...I want these to last a fair while.
        • mariushm
          • May 2011
          • 3799
          Try to get something with low impedance, as close as or below 1 ohm, but don't sacrifice lifetime rating (hours @ 105c) for lower ohms.
          The impedance is not that important for capacitors running at high voltage, in the mains section.
          • redrooster
            • May 2011
            • 114
            Thanks mate,you've answered my question spot on.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
