No Picture or Audio on Insignia NS-LCD26
  • adlegs
    • Sep 2012
    • 29
    I have a Insignia NS-LCD26 that has this issue and I have tried reballing the Main Board to see if it would correct the issue. I used a heat gun the first time and the Tv started working but only for a few days... I baked the entire Main Board 3 weeks ago and thought it had fixed it for good but it stopped working today My question is should I replace the Main Board (6HA0086911) or could something else possibly be causing this issue??
    Thanks for any feedback!!
    Re: No Picture or Audio on Insignia NS-LCD26
    Voltage output of the power supply should be verified first, if the voltages are wrong, lots of strange/intermittent problem can show up.
    http://s807.photobucket.com/albums/y...NS-LTDVD26-09/
    • adlegs
      • Sep 2012
      • 29
      I checked all of the voltage outputs from the power supply and they seem to be good. I can check them again. I also notice a slow startup around 9-10 seconds before the video shows on the screen and also sometimes the TV needs input before it would turn on.
      Dont know if these additional symptoms help or just make it more confusing... Thanks for the input I will check the outputs from the PWB again.
        That is a strange symptom indeed. I have not run into this problem before in this model. The 3 I fixed all have bad caps.
        • adlegs
          • Sep 2012
          • 29
          Thanks for the reply! I will double check the PWB.
          • adlegs
            • Sep 2012
            • 29
            bubm,
            Yes t is strange that when I attempt to reball the video chip by heating to to 385 degrees for 10 or so minutes the set works fine for a while. I was wondering about the startup time... is 8-10 seconds before I get a picture normal for thos model?? also is it normal that the TV needs input before it will show video?? what I mean by that is I have a cable box hooked up to a HDMI input and if the box is off the TV video will not come on. I have to turn off the TV then turn on the cable box and then turn on the TV??? Thought that was kinda strange...
            • infringer
              Badcaps Member
              • Sep 2009
              • 244
              • United Frickin States
              Sounds to me like your video board may need a replacement after cooking it in your oven you are not reballing anything by heating it up you are essentially reflowing I suppose but anyone will tell you with these types of fixes in order to get it to work you may need to truely reball the unit rather then hoping that heat magically gets rid of all of your tin whiskers as it rarely works for extended periods of time.
              PS I need to know some stuff about your power board if you could help me I have this same TV and the SMT chip on the bottom blew off and I need the part number for this chip if you could help by giving me this info it would be great.
              Check out the thread that I started and help if you can.
              Thanks!
              Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
              • infringer
                Badcaps Member
                • Sep 2009
                • 244
                The thread is located here: https://www.badcaps.net/forum/showthread.php?t=23169
                The item I am referring to is on the bottom of the power board.
                Looking at the picture it is marked 24v SMPS IC
                https://www.badcaps.net/forum/attach...9&d=1350273088
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Are you getting back lights? I worked on a Westinghouse 47" that had an intermittent connection failure in the socket for the lvds cable that goes to the tcon. The odd thing is that with the bad connection it killed the 5v from the ps. Thus halting all controls and no picture backlight or video.
                  • adlegs
                    • Sep 2012
                    • 29
                    My screen is completely black no lights...
                    • adlegs
                      • Sep 2012
                      • 29
                      Infringer.... I am going to take it down and look tonight and I will reply with the number.
                      • infringer
                        Badcaps Member
                        • Sep 2009
                        • 244
                        Did you get a fairly intense flashlight and shine it on the screen in the center and hit the menu button? You will see the picture if it is there with a good flashlight...
                        • adlegs
                          • Sep 2012
                          • 29
                          No but I had the back of the TV off and could see the LCD from the back and it does not light up. When it does I am able to see light from the back. But I will try the flashlight and see. Thx!
                          • infringer
                            Badcaps Member
                            • Sep 2009
                            • 244
                            shine the flashlight on the front of the screen in a semi lit room and look hard a dark room is better just be careful if you have the back of the TV off not to touch the power boards... Yes I know you can see the LCD from the back we are trying to see if the screen is still functioning here and your backlight is out or just not starting this is just a simple test really and should be done any time your power comes on and you don't have a picture it is always good to know that the screen is still functional before you dump money and time it to it as it is the most expensive part of the unit so if you can confirm this it will be advantageous for you but not all times does the unit have a picture a frozen picture a half of a picture or no picture or lines may indicate a timing control failure. So keeping this all in mind the flashlight check is handy and should be considered as part of the procedure.
                            Thanks by the way for taking the time to look for them chip numbers ahead of time it'll save me some time.
                            • adlegs
                              • Sep 2012
                              • 29
                              I checked the LCD with a flashlight and do not see anything.... it looks totally black. also my PWB does not look like your pics?? what is the number on the board by the chip?
                              • adlegs
                                • Sep 2012
                                • 29
                                Here are some closeups
                                • adlegs
                                  • Sep 2012
                                  • 29
                                  pic 1170 - 165A
                                  PDLC
                                  pic 1169 - 431AC
                                  (TI emblem) 75M
                                  CJ06 G4
                                  • infringer
                                    Badcaps Member
                                    • Sep 2009
                                    • 244
                                    The unit does power up though correct? If so what are all of the voltages at the power connectors take voltages of everything in standby and when powered on and report all of the voltages here like so...
                                    +5v Standby xx.xxv On xx.xxv
                                    +12v Standby xx.xxv On xx.xxv
                                    +24v Standby xx.xxv On xx.xxv
                                    on/off Standby xx.xxv On xx.xxv
                                    psu on Standby xx.xxv On xx.xxv
                                    This will help leave a little better indication.
                                    Also check all your SMT fuses on your inverter board.
                                    Check all your SMT fuses on your TCON
                                    Check all your SMT fuses on your Main Board.
                                    There should be a fairly nice amount of SMT fuses in this TV.
                                    This would be a great starting point for you to fix the problem there needs to be some electronic indication of where it may be coming from whether it is a fuse or voltage irregularities or something but you surely will need to provide more info at this point.
                                      Can we see good clear pictures of both sides of the power board? Also, what is the full model number of this TV, Insignia will have the main model number and follow by the - xx for the year.
                                      • adlegs
                                        • Sep 2012
                                        • 29
                                        I am checking the voltages your suggested now. Did the pics I uploaded help you?
                                        If it was a fuse blown does the fuse reset? I have heated the video chip 3 times in an attempt to reseat the chip and each time the TV works but only for a few days then no video. The TV sounds like it powers on and I get a green power on light but I have to hold the power button for 5 seconds to turn it off. If a fuse was blown wouldn't it stop working for good until the fuse was replaced?
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • srs
                                          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                                          by srs
                                          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                                          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                                          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                                          04-22-2023, 02:40 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
