samsung on off issue
  • Max88
    • Oct 2012
    • US
    Re: samsung on off issue
    I am having this exact same issue on a Samsung LN40A630, takes a long time to come up, keeps restarting with blinking red light until it does, and when it does come up it has thin snowy multicolored lines throughout the screen followed by a loud high pitched squeal out of the speakers and eventually automatically shuts off. if I have a source input through HDMI. I've tried replacing all the caps on the board (none were blown or bulging) along with bypassing the thermistors with no changes at all. Ive given up on it and just purchased a main board and power supply off ebay because Ive heard suggestions that it may be the mainboard and not the powersupply.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Originally posted by FishFind
      Also I never said before but when it is starting and failing it will sometimes have a very distorted screen "black, snow, green, pink." and a loud pitch squeal from the speakers.
      Hmmmm, Are you running it with an HDMI cable? HDMI cable faults can cause lots of weird things! (like pink screen this - happened to out 42" samsung plasma - I thought for sure the TV was toast, until we went to take it off the wall. Just bumped the HDMI cable and the picture came back!)
      If your using an HDMI cable, try using a different input (like RCA), or just get a new HDMI cable.
      Muh-soggy-knee
      • DavidDunn
        • Sep 2012
        • 10
        Very curious to know if you fixed it or not. I have the same problem. I replaced both
        20N60C3R out sheer speculation. No change. I am going to take Tho's advise and swap out the thermistors. I will post back with the results.
        • bmwracer
          • Mar 2013
          • 32
          Hi all, noob here.
          I'm seeing the exact same problem when I took a look at a coworker's LN40A630.
          The caps looked okay, but I changed them out anyways... No improvement.
          I removed the main board, the one with all the inputs (HDMI, RCA jacks, etc.) to inspect the soldering under a microscope and it all looks okay, even though there's residual flux all over the circuit board... Ugh.
          Haven't changed out the DSC 2.5D-15 thermistors yet, but I will when I find the right ones.
          • samsubby
            • Apr 2013
            • australia
            Has anyone found the resolve for this. I have same prob with Samsung 50. exact same description as Max88.
            • bmwracer
              • Mar 2013
              • 32
              Finally got a hold of some thermistors and changed them out... No improvement.
              My coworker decided to buy a new TV, so he let me keep the TV... Aside from the power up issue, it's a fine TV, so I'll use it in my dining room.
              I really think it's the main board, but it's not worth spending any appreciable amount of money (> $50) to replace it.
              I can avoid the loud screeching noise at power up by just plugging in a 3.5mm plug into the headphone jack during power up and unplugging it when everything is ok after a minute or two... Not the best solution, but it's a free TV, so I can't complain too much.
              • rylo
                • Jul 2013
                • US
                #27
                Hello, Max I too am having the same issues as you are and was wondering if the main board you ordered fixed the issue ?
                • mangina
                  • Sep 2013
                  • canada
                  #28
                  Same issue here, has anyone resolved this?
                  The only fixes I've found on the web are somebody baking their main board and someone else replacing their main board.
                  • Videojoe
                    • Sep 2013
                    • 47
                    • Us
                    #29
                    Look on the back side of the main board and there should be a tantalum cap there. I forget the value but it is a little square surface mount type. Replace it. I got one from digikey for a couple bucks and it fixed the same problem I ha on my Samsung 50 inch although it was a slightly different version.
                    • falcons7
                      • Feb 2014
                      • 5
                      • canada
                      #30
                      Does anyone know the model number for the thirmistors on this board? I've got a pn50a550 with two of these that have blew.
                      • rob3307
                        • Oct 2014
                        • 16
                        Hello all I'm new to the board but am experiencing the exact same issue with the exact same model. I do have pics of the bottom of the board you all want as well...
                        • rob3307
                          • Oct 2014
                          • 16
                          top of board view, circle is where the multimeter slipped testing the fuse and got a spark tv hasnt turned on since, before that it was the same issue as everyone else, turning tv on in morning it would turn on and off atleast 3 times shreaking occasionally but would be fine if i left it on... caps look ok not sure where to start i am a novice to say the least but want to learn about this type of thing hoping to save a nice tv from the dump...
                          https://www.dropbox.com/s/7yw6ma00sr...351_0.jpg?dl=0
                          top view without the circle
                          https://www.dropbox.com/s/90cjn17lmo...30351.jpg?dl=0
                          bottom
                          https://www.dropbox.com/s/zy4jyvv1q0...30329.jpg?dl=0
                          • rob3307
                            • Oct 2014
                            • 16
                            Anyone?
                            • rob3307
                              • Oct 2014
                              • 16
                              bump
                              • rob3307
                                • Oct 2014
                                • 16
                                5702
                                • rob3307
                                  • Oct 2014
                                  • 16
                                  and yes i realize the one fuse is blown wanted to figure out if i needed anything else before i went and got it as i am not using the tv anyway
                                  • hars78
                                    • Jan 2015
                                    Originally posted by tho
                                    Hello fishFind.
                                    I m so sorry to make you comfuse about it. I have no time to get up here until now.
                                    I just want you to clear about it. Look on the picture you posted from point b to piont A and go to the end of the heat sink. do you see the rte-801 and rte-802 ? The next to rte-801 and rte-802 is 2 relay (that is the switch, SDT it is call is single fold double through , black color) go to next is the input power conector. It is 2 pin, righ? .The problem is right there. The power ac input from the connector , 2 pin .It go to the relay sdt switch and from the switch go to the rte-801 and rte-802 and from the point rte 801 and rte-802 to the diot, Righ? If the pin on the sdt cold solder or open . It will burn the rte 801 and 802. or if the the 2 relay (sdt shorted, It will not use the remote control to turn it off, or on. In my case, the rte801 and rte 802 was burn, I troubleshooting from the ac input to the relay (sdt) I found the the 1 pin on the sdt (relay) is cold solder so it make the rte hot and it up. I check the number on the rte 801 and 802 the value is SCK0512 that mean 5 ohm and 12amp and diameter is 20mm. I replace it. It is work ok now.
                                    My TV died yesterday. No power at all.
                                    RTE-801 and RTE802 were burnt (circuit board discolored as well). The solder connections were really bad on the thermisters - because of the heat.
                                    Also replaced capacitor CP808, CP810. They were slightly bulging.
                                    Put all together and works great!. Thank you for your help!
                                    • awyatt2
                                      • Feb 2012
                                      • 407
                                      • america
                                      #38
                                      47uf 10v tant cap I replaced three in three tv's of them and the tvs have been going fine since. got mine through mouser.
                                      • Chazuka
                                        • May 2015
                                        I have the same board, bn44-00222a, with transistors RTE801 and 802 burnt out. Unfortunately, RT801 was slightly bent over and slightly melted the "black box" on RL-YE802. Do I need to worry about the board being discolored if I replace the transistors? And what is RL-YE802 and should i worry about replacing that too? Thanks all!
                                        • notsogentle
                                          • 33
                                          • canada
                                          #40
                                          The Black box is a relay and i think it would depend on the degree of "meltage". I would try replacing the first two and if the relay is too warped to function properly then replace it as well.
                                          I just "rescued" one of these tv's from an electronics recycling bin and after resoldering the cold solder points on the board it came back to life and is working fine again. Good luck with yours
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
                                          • FourRunner
                                            Display issue Samsung TV UA65JS9000W
                                            by FourRunner
                                            I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                            10-03-2024, 07:05 PM
                                          • ScHAmPi
                                            Samsung UE48JU7000 screen issue after backlight replacement
                                            by ScHAmPi
                                            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                            07-15-2024, 05:41 AM
