50pg20 problem
+ More Options
Posts
  • Duckhuntr
    • Oct 2012
    • Usa
    50pg20 problem
    Need some help on this one. I've got a 50pg20 plasma that the picture quit on me. Sounds still works just no picture.
    I recently replaced the power board...I also checked it just now and all the readings with a dmm, everything is fine with the power board.
    My YSus board is not heating up, I can physically feel my ZSus board heating up, but my YSus board is ice cold(the heat dissapaters) when I hook up the power. I have checked all voltages both leaving the power board and also all voltages entering the YSus board. Just to be safe, I bought a new YSus board thinking that was the problem. The new YSus board is also ice cold to the touch after hooking up power. Lastly, I disconnected the power in to the YSus board and checked the circuits in the board, all checked out from a pin check.
    What in the world could the problem be that 2 different YSus boards have power in to them but neither will heat up and act like they are working??
    Re: 50pg20 problem
    Is screen lit up visibly in a dark room?
    Could be control board or buffer board failure.
    Check Vs supply to Y-sus, should be around 200V.
    • Duckhuntr
      • Oct 2012
      • Usa
      Re: 50pg20 problem
      Screen will not show any light in a dark room. Vs supply to YSus is good. I've checked it over and over?
      Are there any checks that I can do to control board or buffer board?
      • freakaftr8
        • Oct 2012
        • 3743
        Re: 50pg20 problem
        Pull your upper and lower buffer boards. Power up. Does it warm up now? Unplug it and Plug one buffer board in at a time. Try upper first. If still dark disconnect upper an connect lower.
        • freakaftr8
          • Oct 2012
          • 3743
          Re: 50pg20 problem
          Btw you can leave the ribbon cables connected from the panel going to the buffers. Just disconnect the buffers from the y sustain.
          • Duckhuntr
            • Oct 2012
            • Usa
            Re: 50pg20 problem
            That is sound advice. Didn't think about doing that. Doing it now, will respond shortly.
            • freakaftr8
              • Oct 2012
              • 3743
              Re: 50pg20 problem
              Any luck?
              • dukesaskatoon
                • Dec 2011
                • 17
                Re: 50pg20 problem
                disconnect all cables from the digital main pwb. then jumper test holes labeled "auto gen" on the control pwb. power on if the screen lites and goes through the test patterns you know everything is good on the display and it is the main pwb that is the issue.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Re: 50pg20 problem
                  I'm eyeballing the same model with the same problem. Were you able to figure it out?
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • DynaxSC
                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                    by DynaxSC
                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                    03-10-2025, 12:27 PM
                  • AstutePauciloquent
                    Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                    by AstutePauciloquent
                    Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                    I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                    11-23-2023, 11:02 PM
