50pg20 problem
  • Duckhuntr
    • Oct 2012
    • 3
    • Usa
    50pg20 problem
    Need some help on this one. I've got a 50pg20 plasma that the picture quit on me. Sounds still works just no picture.
    I recently replaced the power board...I also checked it just now and all the readings with a dmm, everything is fine with the power board.
    My YSus board is not heating up, I can physically feel my ZSus board heating up, but my YSus board is ice cold(the heat dissapaters) when I hook up the power. I have checked all voltages both leaving the power board and also all voltages entering the YSus board. Just to be safe, I bought a new YSus board thinking that was the problem. The new YSus board is also ice cold to the touch after hooking up power. Lastly, I disconnected the power in to the YSus board and checked the circuits in the board, all checked out from a pin check.
    What in the world could the problem be that 2 different YSus boards have power in to them but neither will heat up and act like they are working??
    Re: 50pg20 problem
    Is screen lit up visibly in a dark room?
    Could be control board or buffer board failure.
    Check Vs supply to Y-sus, should be around 200V.
    • Duckhuntr
      • Oct 2012
      • 3
      • Usa
      Re: 50pg20 problem
      Screen will not show any light in a dark room. Vs supply to YSus is good. I've checked it over and over?
      Are there any checks that I can do to control board or buffer board?
      • freakaftr8
        • Oct 2012
        • 3743
        Re: 50pg20 problem
        Pull your upper and lower buffer boards. Power up. Does it warm up now? Unplug it and Plug one buffer board in at a time. Try upper first. If still dark disconnect upper an connect lower.
        • freakaftr8
          • Oct 2012
          • 3743
          Re: 50pg20 problem
          Btw you can leave the ribbon cables connected from the panel going to the buffers. Just disconnect the buffers from the y sustain.
          • Duckhuntr
            • Oct 2012
            • 3
            • Usa
            Re: 50pg20 problem
            That is sound advice. Didn't think about doing that. Doing it now, will respond shortly.
            • freakaftr8
              • Oct 2012
              • 3743
              Re: 50pg20 problem
              Any luck?
              • dukesaskatoon
                • Dec 2011
                • 17
                Re: 50pg20 problem
                disconnect all cables from the digital main pwb. then jumper test holes labeled "auto gen" on the control pwb. power on if the screen lites and goes through the test patterns you know everything is good on the display and it is the main pwb that is the issue.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Re: 50pg20 problem
                  I'm eyeballing the same model with the same problem. Were you able to figure it out?
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • PlasMatt
                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                    by PlasMatt
                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                    09-20-2025, 06:50 PM
                  • PNI E.
                    Dyson v15 problem with the dust detector board
                    by PNI E.
                    Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
                    10-02-2025, 10:18 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
